Old 12-28-2015, 07:51 PM
Cooper's Avatar
Cooper Cooper is offline
So that black motor is what diameter & what kv?
56mm by something like 93~100mm. 1200kv
Old 12-28-2015, 08:04 PM
Cooper's Avatar
Misprint on the one post, the gearbox is 4:1, 4:1, 3:1 and diff is 3:1, 1200kv motor on 11.1v Lipo, 144:1 reduction. 13320rpm on motor , axle will be 92.5 rpm. Now i don't know what the motor will actually spin. Kv is not an exact science and these TP motors are cheep so the windings very well could be off a couple hundred at most. And with such a big motor I really don't want to be maxing it out on top end. I think the power will be there and I can limit speed with radio if needed.
Old 12-28-2015, 08:15 PM
bigford's Avatar
bigford bigford is offline
you need a large cat under the hood. just so
happens you know where there is one.....
Old 12-28-2015, 08:51 PM
Cooper's Avatar
Hummm, get Brian to print that engin around my motor, or I'm stuffing this "shop cat" that keeps jumping on my lap in there!!!
Old 12-28-2015, 09:02 PM
Cooper's Avatar
That's what I'm talking about!! Something wrong with this cat!! It just stares at me like that!!!
Had one shot to get the spacing and brazing on this, I think I got both
Probably don't need the bearing there but doing it anyway. Two bearings just inside the block on shaft. The exposed one will be in diff housing. It will also add to the integrity of the mounting.
This "should" be beefy enough, I'm thinking.
Old 12-28-2015, 09:42 PM
Cooper's Avatar
Got some bearings, not sure who makes them? Butt I was thinking of you mark, when you asked what the gear shaft was for.
HAHAHAHAH ������
Old 12-28-2015, 09:44 PM
Cooper's Avatar
Just couldn't help myself ,,, again,, I know back to the garage i go.
Old 12-28-2015, 10:07 PM
bigford's Avatar
all my bearings say paccar on the box those must be english bearings
Old 12-28-2015, 10:24 PM
HAHAHAHAH ������
I guess those are rear end bearings?
Old 12-28-2015, 10:36 PM
Bo Wallen's Avatar
Exclamation Re: Great Dane excavating co.
Does no look strait to me.........................
Old 12-28-2015, 11:50 PM
jack van's Avatar
jack van jack van is offline
did you use enough presure when insertting the bearing ?
Old 12-29-2015, 07:16 PM
Cooper's Avatar
Question for you guys, I don't do much turning on steel,, feed is .005 rpm is 200. This is what the chips look like. I know I can push it to getting ideal blue chips, just want some advise on speeds n feeds.
At this rate I will be here for a day, have to take gearstock from about 1.2" down to .3125". I may go with shaft and keyway but then I have to broach gears. Wanted to keep one piece shaft and gear. Lathe is 10x22 variable speed. Using insert cutter.
Or is it no matter what going to be timely? I just don't know with steel cutting.
Old 12-29-2015, 07:27 PM
That gear stock material is really nice to machine. You may want to put a center hole and use the tail stock for better support. You should be able to hog more off faster.
As far as taking all day; It's a hobby you aren't making any money and its the fun of doing this. I would go with the one piece gear and shaft. Less worry, besides by the time you make a shaft key it bore the gear and broach you will have way more time than just turning the gear stock.
Old 12-29-2015, 07:29 PM
Forgot to mention, More feed may push the gear into your collet. Do you have a stop in it?
Old 12-29-2015, 07:48 PM
Cooper's Avatar
No stop, but I did center hole and live center. That was one thing I was worried about, pushing the shaft. I turned a piece of alum and cut it into three for a soft jaw. Clamped down pretty good but still having the teeth there. Have been checking it a couple times.
Yeah, I've got more time than anything . Thanks Steve, see you in a couple weeks?
Old 12-29-2015, 07:55 PM
We will be there. I still need to get my machine out of the trailer and do some wiring on the new control console. It's been in there since Labor Day We have been very busy here at work with not much time for play.
Old 12-29-2015, 10:47 PM
Cooper's Avatar
Yeah I need to start getting stuff around for the show also. Messed up my shoulder with work stuff, can't lift above my head so hand cranking wheels at home has been therapy . You are right about that gear stock being easy to cut. I guess I base my steel experience on hardware store stock. Doesn't cut well, and never a good finish. Last project I got steel ordered, easy to machine kind. Slowly learning to get the correct materials to make the job easier. That shaft wasn't bad to cut my inexperience showing again.
The smaller gear on shaft is the one inserted into gearbox, it will be keyed to shaft. Top gear will be connected to a driveshaft. Only hard part now is getting the correct spacing on gears into gear housing.
Old 12-29-2015, 11:04 PM
Lookin good! When I built the rears for my 850 KW I used a piece of regular paper sandwiched between the gear mesh and then took the measurement for the spacing. Gear lash seamed to be pretty good and hasn't given me any grief just yet.
Old 01-02-2016, 08:57 PM
Cooper's Avatar
I've always done that with other toys, this time I had the schematics of pitch and diameters. Actually did something by the book!!.
Old 01-02-2016, 08:58 PM
Cooper's Avatar
Currently Active Users Viewing This Thread: 57 (0 members and 57 guests)
