#1281
56mm by something like 93~100mm. 1200kv
#1282
Misprint on the one post, the gearbox is 4:1, 4:1, 3:1 and diff is 3:1, 1200kv motor on 11.1v Lipo, 144:1 reduction. 13320rpm on motor , axle will be 92.5 rpm. Now i don't know what the motor will actually spin. Kv is not an exact science and these TP motors are cheep so the windings very well could be off a couple hundred at most. And with such a big motor I really don't want to be maxing it out on top end. I think the power will be there and I can limit speed with radio if needed.
#1283
you need a large cat under the hood. just so
happens you know where there is one..... |
#1284
Hummm, get Brian to print that engin around my motor, or I'm stuffing this "shop cat" that keeps jumping on my lap in there!!!
#1285
![]() That's what I'm talking about!! Something wrong with this cat!! It just stares at me like that!!! ![]() Had one shot to get the spacing and brazing on this, I think I got both ![]() ![]() Probably don't need the bearing there but doing it anyway. Two bearings just inside the block on shaft. The exposed one will be in diff housing. It will also add to the integrity of the mounting. ![]() This "should" be beefy enough, I'm thinking.
#1286
![]() Got some bearings, not sure who makes them? Butt I was thinking of you mark, when you asked what the gear shaft was for. HAHAHAHAH
#1287
Just couldn't help myself ,,, again,, I know back to the garage i go.
#1288
all my bearings say paccar on the box those must be english bearings
#1289
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I guess those are rear end bearings? |
#1290
Does no look strait to me.........................
#1291
did you use enough presure when insertting the bearing ?
#1292
Question for you guys, I don't do much turning on steel,, feed is .005 rpm is 200. This is what the chips look like. I know I can push it to getting ideal blue chips, just want some advise on speeds n feeds.
![]() ![]() At this rate I will be here for a day, have to take gearstock from about 1.2" down to .3125". I may go with shaft and keyway but then I have to broach gears. Wanted to keep one piece shaft and gear. Lathe is 10x22 variable speed. Using insert cutter. Or is it no matter what going to be timely? I just don't know with steel cutting.
#1293
That gear stock material is really nice to machine. You may want to put a center hole and use the tail stock for better support. You should be able to hog more off faster.
As far as taking all day; It's a hobby you aren't making any money and its the fun of doing this. I would go with the one piece gear and shaft. Less worry, besides by the time you make a shaft key it bore the gear and broach you will have way more time than just turning the gear stock. |
#1294
Forgot to mention, More feed may push the gear into your collet. Do you have a stop in it?
#1295
No stop, but I did center hole and live center. That was one thing I was worried about, pushing the shaft. I turned a piece of alum and cut it into three for a soft jaw. Clamped down pretty good but still having the teeth there. Have been checking it a couple times.
Yeah, I've got more time than anything . Thanks Steve, see you in a couple weeks?
#1296
We have been very busy here at work with not much time for play.
#1297
Yeah I need to start getting stuff around for the show also. Messed up my shoulder with work stuff, can't lift above my head so hand cranking wheels at home has been therapy
. You are right about that gear stock being easy to cut. I guess I base my steel experience on hardware store stock. Doesn't cut well, and never a good finish. Last project I got steel ordered, easy to machine kind. Slowly learning to get the correct materials to make the job easier. That shaft wasn't bad to cut my inexperience showing again . ![]() ![]() The smaller gear on shaft is the one inserted into gearbox, it will be keyed to shaft. Top gear will be connected to a driveshaft. Only hard part now is getting the correct spacing on gears into gear housing.
#1298
Lookin good! When I built the rears for my 850 KW I used a piece of regular paper sandwiched between the gear mesh and then took the measurement for the spacing. Gear lash seamed to be pretty good and hasn't given me any grief just yet.
#1299
#1300
| Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
| Thread Tools | |
| Display Modes | |
