Old 02-16-2016, 07:26 PM
SmallHaul's Avatar
Default Re: Mack DT 3rd rebuild
Originally Posted by Claus View Post
Scott how is this truck holding up after all these years? Have you ever broke any of the drivetrain? Are your axles locked?
One of the Classic builds.
It is holding up nice Craig, the only thing that i had to do it lately was re-glue a couple of tires that spun loose.
The axle are all modified with rubber washers in place of the metal shims in the diffs. The rubber washers force the spider gears together so hard that it acts like a posi rear end but, if you are carrying 15 pounds of dirt and turn sharp the spider gears will turn.
You can really see them all turn in this vid @ 3:50 mark.
https://www.youtube.com/watch?v=_H-dIBU6laM
Last year i had to open one axle up because the posi action was gone and i found the rubber washers were ground to shreds. So, i cleaned it out and made new washers for it. I just took both of the axles out of the king hauler after the Cabin Fever show and did the rubber washer mod to them as well.
Originally Posted by Bo Wallen View Post
Looking Good Scott. I like that old workhorse keep going Sir.
Thanks Bo. :-)
Scott
"No load is too Small"
Old 02-16-2016, 07:59 PM
Supermario's Avatar
I hope everyone is paying attention! This is golden RC info to have from one of the best! Great thinking Scott. I'm definitely doing that to my dump truck. I have a 4th spider in there right now so nothing permanent about it and can do this!
Old 02-16-2016, 10:23 PM
SmallHaul's Avatar
Thank You very much Supermario!
To make the rubber washers i use regular thickness bicycle inner tube rubber and just cut them to shape and add some fresh grease to the spider gears just before you final assemble.
Scott
Old 02-16-2016, 10:29 PM
SmallHaul's Avatar
I should also add that the tight fit of the rubber washer against the backside of the bevel gear and diff housing also contributes greatly to preventing the spider gears from rotating..it is not just the pressure on the spider gears that makes the mod work. Which is probably why the gears seem to be holding up fine.
Scott
Old 02-16-2016, 10:46 PM
Bo Wallen's Avatar
Lightbulb Re: Mack DT 3rd rebuild
Right Mario spot on and Scot knows how to drive too. and that is important folks watch the video how to make the hill like it was a minor bump !!!
Old 02-16-2016, 10:54 PM
doodlebug's Avatar
Way to innovate!
Cheers!
Old 02-16-2016, 11:22 PM
Claus's Avatar
Claus Claus is offline
Tough little truck Scott!
