Old 02-29-2016, 08:17 AM
Snowman3725
Guest
Posts: n/a
Default Six speed?
Is anyone aware of a transmission or add on splitter that will give me 6 or 9 gears instead of the stock 3 in tamiya transmissions?
Old 02-29-2016, 05:05 PM
Default Re: Six speed?
there have been people who have bolted up another tamiya 3 speed to the back of the stocker, but i think that only gives 3 more, as the others overlap..
maybe a r2 or something would work
Old 02-29-2016, 05:47 PM
bigford's Avatar
bigford bigford is offline
two 3 speeds give you alot of the same gear combos not worth the work involved to do it
Old 02-29-2016, 06:21 PM
Bo Wallen's Avatar
Lightbulb Re: Six speed?
A three speed hooked to a two speed will give 1-2-3 / high-low.
Old 02-29-2016, 06:22 PM
You gotta make a high/low/direct to bolt on the back . I've the idea kickin around in my head for some time now . It just make no sense what so ever with the use of electric motors and the available gear reduction units available .
Old 02-29-2016, 06:25 PM
Bo Wallen's Avatar
Steve. Could be fun...........more gear more fun...........
Old 02-29-2016, 06:52 PM
Snowman3725
Guest
Posts: n/a
I think it would be more realistic. I have the 7:1 reduction in now but 6 or 9 or 18 gears? **** of a lot more fun! My technical abilities aren't suffice to build anything on my own. Any takers??
Old 02-29-2016, 07:27 PM
mcl fabrication mcl fabrication is offline
mcl fabrication is on a distinguished road
I would love to take my king hauler up a hill with a load, along with 6 gears to run threw!!
My sound unit would sound amazing.
Old 03-01-2016, 12:40 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
Someone made a 6 or 9 speed years ago on here and was trying to market it he had it fitted into a ford earomax daycab (back when Freddy was here) not oztruck (chris) but oztruck did bolt two 3 speeds together and call it a 9 speed,
It was bulky and a hole had to be cut in the back of the cab to fit it,
So might be a idea of searching the forum going backwards from when freddy past away and it might still be on here I think it was ether in highway trucks or general, but it was defenatly before freddy past away............
Cheers Tracy
Love my Kenworths
Old 03-01-2016, 12:50 AM
Cossett's Avatar
On Leave
Ok I just googled Oztruck and it show both gearboxs
http://australian-rc-truck.proboards...box-joey-diffs
Cheers Tracy
Love my Kenworths
Old 03-01-2016, 01:18 AM
Cossett's Avatar
On Leave
With the options of different motors / pinions and gear reduction - transfer boxs today and some that enable you to change gears via reduction - transfer boxs with servo it would probably cheaper and hide them better then making a bulky all in one gear box........
Cheers Tracy
Love my Kenworths
Old 03-01-2016, 02:12 AM
Snowman3725
Guest
Posts: n/a
Now my gears are really turning. Pun intended. I wonder who makes that 2 speed add on gear box? The videos don't do any justice. Maybe a vendor will see this thread and make something simple like a small 3 speed splitter that can be installed after the transmission. While I'm thinking of it, anyone have any knowledge of a transmission that has a front output shaft for awd?
Old 03-01-2016, 02:35 AM
Cossett's Avatar
On Leave
I thing the Tamiya 1/10 RC Toyota Hilux High-Lift gearbox is AWD from memory and reading about it on here ,
Have a google for it..
Cheers Tracy
Love my Kenworths
Old 03-01-2016, 03:41 AM
Snowman3725
Guest
Posts: n/a
Question Re: Six speed?
Cheers Tracy
Sure does look like it. Aside from having to create brackets to mount it and hoping the drive shaft angle doesn't interfere with bottom of trans, this just might work. Or I could somehow attach an output shaft to the outside of the main bearing…
