Old 04-11-2016, 10:11 AM
Hwheeler1973 Hwheeler1973 is offline
Hwheeler1973 is on a distinguished road
Default My first Semi build, KW W900L
Hi everyone! I've built a few custom RC's in the past but never a semi. There is definitely some different tech involved in these verses just a 4wd crawler. And the price difference is way more on these! But I'm definitely into it and I've already made some good headway. I've posted some of my progress on the Facebook page but i figured I better do it the right way here in the forum. Here are a couple pics of more or less what I'm shooting for.
Last edited by Hwheeler1973; 04-11-2016 at 10:14 AM. Reason: Trying to get the pictures the way they should be
Old 04-11-2016, 10:22 AM
Default Re: My first Semi build, KW W900L
Some frame and chassis setup. I'm using Lesu axles and single airbag suspension. Don't mind the super sized tires! I only used them to get things going in my mock up!
Old 04-11-2016, 10:28 AM
On to the scale motor and motor/tranny setup. As for the scale motor, I've seen some guys use an arm mounted to the bottom of these as a go between from the servo to the steering. I wanted to do something different tho. I used a low profile servo and mounted it inside the motor.
[IMG] [/IMG]
Old 04-11-2016, 10:33 AM
Im using an Axial, rebuildable, 55T motor and a Veroma Models 3 speed transmission. Very nice setup! Everything fits down inside the rails nice and neat!
[IMG] [/IMG]
Old 04-11-2016, 10:40 AM
I got this body through Shapeways. It was designed by Goose19. I gotta say, he did an amazing job on the CAD design!
[IMG] [/IMG]
Old 04-11-2016, 10:48 AM
And now what I've got so far for my LEDs. Both of these bumpers came from Russ at True Scale. He makes some awesome stuff! All of the LEDs that are lit up are 1.8mm.
[IMG] [/IMG]
Last edited by Hwheeler1973; 04-11-2016 at 10:52 AM. Reason: Uploaded the wrong pics
Old 04-11-2016, 11:26 AM
bigford's Avatar
bigford bigford is offline
nice kw your building there!!
Old 04-11-2016, 12:41 PM
Thank you bigford!
Old 04-11-2016, 01:57 PM
Northern Farmer's Avatar
Thumbs up Re: My first Semi build, KW W900L
Wow this is your first truck build ? Come along very nicely
Old 04-11-2016, 02:31 PM
Northern Farmer, yes. This is my first semi build but not my first custom RC build. Thank you!
Old 04-11-2016, 02:59 PM
rccrazy523 rccrazy523 is offline
rccrazy523 is on a distinguished road
Absolutely beautiful start looks great
Old 04-11-2016, 03:42 PM
Thank you!
Old 04-11-2016, 04:58 PM
up9018 up9018 is offline
Wow, that is looking great. I'm a big fan of the large KWs too.
Old 04-12-2016, 03:17 AM
nenard's Avatar
nenard nenard is offline
nenard is on a distinguished road
Looks like its gonna be a rolling light show. Off to a great start.
Old 04-12-2016, 07:45 AM
Thank you! I've always loved the W900L with a studio sleeper.
Something like that!
Old 04-12-2016, 08:48 AM
bigford's Avatar
allan cads up some nice stuff for shapeways to print. i just
wish they could get the grain down more..
Old 04-12-2016, 08:53 AM
I agree! It definitely takes some work to get them smoothed down to paint. I've got 3 coats of primer on it now and still not quite ready for paint.
Old 04-12-2016, 11:46 AM
My next step on the lighting was the drop visor. The one I'm using is a Gear Head stainless steel one. I had an idea to put the clearance lights in it instead of using roof lights. All of my LEDs and lenses for my bezels are clear. I don't want any color showing until they are turned on. The closest roof lenses to the real KW's are the ones that are used on the Aeromax trucks. The problem for me is that they are orange. So... I found a solution!
[IMG] [URL=http://s359.photobucket.com/user/hwheeler73/media/image_zpsbwbperid.jpeg.html]
Old 04-12-2016, 12:00 PM
As with the bumper marker lights, I've used 1.8mm LEDs. I did have to cut the upper corners of the windshield area some to allow for the LEDs and wiring. When the visor is mounted to the cab, you can't see the area that I cut and there is still plenty of area to mount the windshield to.
[IMG] [/IMG]
Old 04-12-2016, 01:02 PM
bigford's Avatar
my 379 hood looked ok in primer then the paint went on
and all the grain popped even after 3 coats of high build primer.
