| Construction News New kits & accessories offered in the world wide marketplace |
when I was doing some research about rc4wd bulldozer on aliexpress, I found out about this
1/12 Scale RC Hydraulic Loader Metal and RTR for 1250$ 1. Dimensions: 53 cmx22cm x27cm Weight:15kg 2. All carbon steel production. 3. The brushless pump pressure of 4 mpa, theoretical maximum lifting weight 13.5 kg 4. All products are the standard tensioning crawler device, automatic tension! The clay sand moving not card master. 5. Contains oil cylinder x3. 6. A full set of debugging, contains rich, 6, 2.4 g remote control. Players should bring along their own 3 s 11.1 v battery. What do you guys think of that? There is a video also on the link. |
No one?
It' s a quite new model and I haven't seen any in operation, or seen any reviews. see they have a new dozer out also. Same fabricator as the 'KAT' excavator, that are in aluminium. I would say it's good if it's all steel, which make it more sturdy. It's a good price, one does not take any big risk cost vice. The 'biggest issue' here is probably the hydraulics, one should not have to high expectations in this price range. Generally check all screws regarding hydraulic fittings and so on before first trial run...In this price range they don't spend too much time controlling and checking before shipment. Just drive on until things possible start leaking too much, and then replace it with e.g German hydraulics, like Leimbach (no point in putting too much energy in getting hydraulic replacement parts from the supplier, just go for better stuff at once from other sources. even if one have to put in another 5-600 USD to make it run great one still got a relative cheep machine)
Probably wouldn't be bad for a starter machine, learn how to work on, and learn the hydraulic system, but dosent look very detailed or strong in construction from the pictures I see.
David |
does the scale really flush out to 1/12th? I am not sure what it should be for 1/12th scale.. but 22" long by 8" wide seems a bit smaller that 1/12 scale..
maybe one of you more experienced scale guys can comment!! It does look cool and I like the price... and for a starter may be just the thing for me too.... Regards, Jeff |
I think for the price I would add a Lil more money and get the magom looks more realistic and they have come a long way
It's a quite suitable size for the 1:Tamiya trucks it's seams out of the video. They can give the scale to whatever they want, it might be 1/12 of a original model XXX, but it's quite simplified and does not look like any specific original model, so difficult to 'arrest' them when it comes to scale) Maybe these Chinese companies mainly just put 1/12 to make their models seam 'bigger and better' than the 'small' 1:14 stuff, that they are designed to work along with) Who knows..well, it doesn't matter, can't complain about the price at least)
Is there any information on the drive train. Track loaders and wheel loaders in general need to have specific gear ratio to make driving into piles of material and ripping up dirt effective. It does look very nice in my opinion.
Well, did anybody get one of these yet?
i was thinking about it, but cant pull the trigger
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
