Old 07-08-2016, 08:20 PM
TRUCKMAKER's Avatar
Default Re: Hayes HD Dump Truck - Take II
Reg your truck and parts are looking great as always! Do you form your own small brass angle or do you have a source to buy it from?
Old 07-08-2016, 09:58 PM
Originally Posted by Northern Farmer View Post
Man all these details are killing it! The tanks and strap brackets look bloody great!
Thank you sir!
Originally Posted by Doggy View Post
Brass is really great material to do small details. And when you have a killer alu body like this, you cant result with less than a masterpiece!
If you hit you bumper to a rock, will it bend like the real one? That was my idea, to press form alu panels over milled body to get thin alu panels that will be damaged like the real thing when driving. It was more od 1/10 trail hilux idea, than 1/14, but I think it would be cool.
I don't think this bumper will dent easily. It's 063 5052 so it's strong.lol I have thought about building a dump bed for myself that is soft though.
Thanks! Angle is home brew. I just sheared and bent it. Not as crisp of an edge as I would like but it will do. Like I said before, I've never worked with brass sheet before. So far it seems pretty good. When I made other parts out of copper sheet it was more difficult. The brass shears and bends and solders nicely. It also takes more heat than the copper before it goes soft. Not too many more parts will be brass on this but there might be the odd thing. Mostly aluminum from here on out.
Old 07-08-2016, 10:22 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Reg, Your brass work is outstanding. Not getting as crisp of an edge actually looks better than if you had used boughten angle. Boughten angle actually has too sharp of an edge. Works great for making frames but does not look as good as yours for making bracing. Now I have to learn your techniques for aluminum forming.
Any of your handmade vehicles put most of us in a second class when it comes to accuracy and realism. I look forward to seeing any of your builds.
LYNN
Old 07-11-2016, 11:57 PM
Thanks very much Lynn. I have a lot to learn with all of this but the brass seems fairly forgiving compared to working with aluminum all of the time. I think I would benefit from having a MAP gas torch so that I could heat things up quicker on larger objects? The torches I have seem to work well on most things though. I am enjoying working with the brass. I wish I had used some of it on my big KW but I also didn't have a lot of the tools that I have now back then. I guess that's called progress...
OK, so a few days have gone by and I've been working on this pretty much steady. When I'm not working on it, I'm thinking about it to the point where I'm losing sleep again. Oh well, I guess it's good to be excited about your work.lol
Anyway, it may not seem like I've accomplished much but a lot of the stuff has been fiddly and time consuming. I made a plate for under the hood and mounted the electronics, planned out where the wiring would go, took the plate out, drilled holes, routed wires, ect. I also made the air tanks although only one is mounted right now because I'm a bonehead and didn't take pictures of the brackets holding the others in place on the 1:1 truck. There are a few other details as well but no point in rambling on. I got started on the dump box today so I feel like I've seen the top of the mountain and have started down the other side! This box is going to be a challenge but they all are in same way or another...lol
Old 07-21-2016, 12:13 AM
I beam, I beam, I beam!lol A ton of work has gone into this truck but it is getting there!
Old 07-21-2016, 12:58 AM
Just stunning! Almost a shame for this sucker to get any paint.
Old 07-21-2016, 04:31 AM
Doggy's Avatar
Doggy Doggy is offline
Doggy is on a distinguished road
Beams look superdupermegacool!
Old 07-21-2016, 08:28 AM
TRUCKMAKER's Avatar
Outstanding Reg. Not enough words! It would be a hard one to paint it looks so good.
Old 07-21-2016, 10:29 AM
Thanks guys. Yes, I am very nervous about painting it. Painting is not my forte so until it's done I will be stressing. I'm hoping to get the truck completed soon so that it gets painted while it's still summer and warm out. The plan is to have the box powder coated(silver) and the rest will be yellow except for a little green on the hood top. At least these trucks had pretty simple paint jobs! I think there is at least 1-2 weeks worth of work left to do on her yet. I will see what I can get done in the next day or two and then it has to go back on the shelf while I work on a job that showed up yesterday. for the HD but for the other job.
Old 07-21-2016, 11:14 AM
tc1cat's Avatar
Super Moderator
Reg,
What do you use for a primer on the aluminum? This has always been a sticking point with me. Either use no primer and hope or make a mess trying different paints!!
LYNN
Old 07-21-2016, 12:44 PM
I usually only prime stuff that needs some light bodywork. I use regular spray paint most of the time so it sprays on thick. Too many coats add up and I lose details. My Hayes is painted with Valspar paint and the box still hasn't worn thru from hauling gravel. The KW is done with Plastikote. Both seem to spray and stick well. I was told they are both made by the same manufacturer but I can't say for sure.
Old 07-21-2016, 12:46 PM
FabOne's Avatar
FabOne FabOne is offline
FabOne is on a distinguished road
Reg-
Your attention to detail blows me away! Keep us posted!
-Terry
FabOne
NW Ohio
Old 07-23-2016, 09:59 PM
Thanks Terry!
Another update. These dummy hydraulic cylinders are giving me fits! I've said a lot of bad words and that's not like me at all..
Old 07-23-2016, 10:25 PM
Northern Farmer's Avatar
Bonerific!
Old 07-23-2016, 10:44 PM
BAHAHAHAHA!!!!!!!!!
Old 07-23-2016, 11:28 PM
TRUCKMAKER's Avatar
Looks great Reg! And yeah what he said ^^^^^. Or did!
Old 07-24-2016, 12:07 AM
Kaan's Avatar
Kaan Kaan is offline
Kaan is on a distinguished road
Wow, looks awesome
Old 07-24-2016, 01:21 AM
bigford's Avatar
bigford bigford is offline
if you ask rw nicely he will make them cylinders work
Old 07-26-2016, 12:53 AM
Did a lot of chin wagging while visiting your shop last week... in disbelief now that I didn't ask to see you strike a few arcs to see your magic happen in person... musta got heat stroke on Saturday...
Great work, as always
Old 07-26-2016, 09:45 AM
Thanks guys. Yes, we had a great BS Joe! It was good to finally meet you in person and shoot the breeze over the weekend. I don't think there is much magic in my welding ability though. The magic is in the grinding filing and sanding afterward!
