Old 10-30-2016, 09:09 PM
crusher's Avatar
crusher crusher is offline
crusher is on a distinguished road
Default RC4WD Pump question
Hi I purchased the pump sold by rc4wd, they apparently use them in the excavator sold by them, my problem is the output shaft on these pumps sticks out 3/16", I know some of you use these, how do you overcome the short length of output shaft? I am going to use belt pulley reduction. I tried turning a small extension, but with so little to hook to it is hard to keep any wobble out of it.
Thanks
Terry
Old 11-03-2016, 12:25 AM
Default Re: RC4WD Pump question
Not sure what the stock output shaft looks like in the pump, but If you have a lathe at your disposal, take the pump apart and see if you could turn a new output shaft all together?
Old 11-03-2016, 02:29 PM
tracksntreadslou's Avatar
Im am thinking that you could make the pump mount so that it also supports a bearing block on the opposite side of your belt pulley..you will need some support there anyways as there will be some force pulling on your shaft
Old 11-03-2016, 03:25 PM
crusher's Avatar
Thanks for your replies, both good advice, I have decided to mount the pump direct to the motor and control with the esc.
Terry
