Old 08-11-2016, 03:07 PM
kaptain Jack's Avatar
Default Re: WRECKER
Brandon, the actuators are:L 12-30-210-6-R
Old 08-11-2016, 04:18 PM
Northern Farmer's Avatar
Default Re: WRECKER
Originally Posted by kaptain Jack View Post
A question for electronics savvy: Did a test drive today with all the functions connected, Firgellis are working fine, however, when connecting winch motor with its own speed control and its own battery,to the RX, the truck goes full throttle....
Could it be electrical interference ? Jack have you tried moving the wires around that power the winch while it's working to see if it effects anything.
Old 08-12-2016, 05:21 AM
gismow's Avatar
gismow gismow is offline
Default Re: WRECKER
Hi do you have a schematic drawing of the cabeling or some photos to get an overview what is setup at the moment?
Greetinx
Peter
Old 08-12-2016, 08:45 AM
Default Re: WRECKER
When you run 2 esc, you are supposed to pull the red wire out of the RX plug on one esc so the 2 bec in them don't fight over trying to power the rx. Lift the tab and slide it out and just heatshrink or tape it out of the way. It'll smoke the bec inside one of the esc fairly quickly if you don't.
It gets even more important when running 2 isolated battery packs, or external bec.
http://www.rccrawler.com/forum/elect...otors-etc.html
If that doesn't get it, post a pic or wiring diagram of your setup.
Old 08-12-2016, 09:37 AM
Default Re: WRECKER
Great advice Frizzen, I'll look into it. Mean while, I changed the esc, from chinese to RC4WD and it seems to work fine.
here is the picture of aftermarket esc
I'll try again with aftermarket later on today and will pull the red wire out, will post the results.
Thanks to everyone who replied to my question.
Old 08-19-2016, 10:48 AM
Default Re: WRECKER
Disconnecting red wire from rx connector worked great!! But now, new question: I have attached retracting legs to the rear of the truck (Tamiya, the ones that go on the trailer), I have only one channel left on the radio, up and down switch I thought of using it to deploy and retract legs. I soldered the motor wires to the the motor of the servo and it works,however, the travel distance is to short !!! Disconnecting the stopper on the servo makes it rotate continuously non stop. Any suggestions on how to deploy the the legs?
Thanks
Old 08-20-2016, 02:38 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
Default Re: WRECKER
Depending on what radio you have you could run another RX and have it in a different model memory like others do when you run out of channels or just but a new radio with more channels...
Cheers Tracy
Love my Kenworths
Old 08-20-2016, 10:31 PM
Default Re: WRECKER
Glad to hear pulling the wire got the esc working!
Does your radio have 'epa' or end point adjustment on that channel? If so, you can start dialing the endpoints further away from center until you're happy.
If it doesn't, you might be able to fit a 'servo stretcher' in the model that wires between the rx and servo to control endpoints. Its a set of pots and a circuit card that let you configure center and each end stop independantly, so they take some time to fiddle with.
Old 08-21-2016, 12:16 PM
Default Re: WRECKER
Thanks Tracy. Thanks Frizzen, I'll see what my radio is capable of doing.
Jack
Old 08-23-2016, 09:20 AM
Default Re: WRECKER
Old 08-23-2016, 11:09 PM
spudd spudd is offline
Default Re: WRECKER
great idea on the rear down riggers
RIP FREDDYGEARDRIVE
Old 09-17-2016, 11:21 AM
dabears's Avatar
dabears dabears is offline
Default Re: WRECKER
Starting to look like the 50 Ton I used to drive before I moved back to Illinois. Great start!
Old 09-17-2016, 09:43 PM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
Default Re: WRECKER
Looking good Capt!
Cheers
Paul
PKD Scale Engineering
Old 10-21-2016, 02:39 PM
Default Re: WRECKER
Did some more work on the truck
Old 10-21-2016, 03:17 PM
Default Re: WRECKER
Beautiful work!
Old 10-22-2016, 01:15 AM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Default Re: WRECKER
Great work so far, Looking forward to more pics and updates.
Old 11-18-2016, 09:54 AM
Default Re: WRECKER
Getting close to finish line
Old 11-20-2016, 11:07 AM
pontiacmann pontiacmann is offline
pontiacmann is on a distinguished road
Default Re: WRECKER
very nice work
Old 11-20-2016, 11:28 AM
scottyk scottyk is offline
Default Re: WRECKER
That is awesome! Doing great man
Old 11-20-2016, 08:07 PM
1985 kenworth's Avatar
Default Re: WRECKER
wow jack looks fantastic..let me know where i can pick it up when its finished
dwayne
