| Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
#101
Here's a couple quick pictures of a dolly I made to pull a pup trailer behind my 6x6. The hitch is removable so I can install a short standard style hitch for pulling doubles. I haven't built the short hitch yet.
#102
Fanstasic build!!
I'm curious about the walking beam setup. Does it have any straight bump/droop travel? For example, on level ground as you increase the load in the bed, would the suspension begin to compress at all? It looks like the only suspension movement is when it's articulating, but perhaps I missed something in the build?Can't believe how small it makes those tires look! I love it.
#103
Thank you for the comments TommyR
![]() The rear suspension is based on a Hendrickson "R" model solid mount suspension. http://www.hendrickson-intl.com/Truc...ional/R-Series The truck was based off a Western Star 6900XD which has larger tires. Before I could find the tires I wanted these kinda grew on me and when it's loaded and off road the it'll stuff the tires. They also work very well off road. So I decided to leave well enough alone. At least for now, ![]() ![]()
#104
Ah ha! And now I know.
Thanks!
#105
wow lots of progress! amazing!
#106
Nice Dolly! I'd suggest moving the 5th wheel hitch forward to get the 5th wheel pin centered over the suspension on the dolly, to get a level ride with no porpoising.
WILDCAT T&C Jim B. Colorado Springs |
#107
Sorry about photos folks, you can thank photobucket for their greed.
#108
#109
How are you uploading now? I'm still using Photo$ucket but I know my account will be gone next year so I need to switch things up.
#110
Props go to Northern Farmer (Brandon) for the image host link.
#111
Truck looks like a beast great job on the build 👍👍
#112
Thanks for the comment Brandon and the link to postimg.org. The truck is actually still a work in progress and after a few more tweaks I'm going to rerail it. I've changed and upgraded so many things over the last couple years the frame rails are looking like Swiss cheese. |
#113
#114
Nice looking screw drive Kent! It almost looks like a CNC's ball screw. With the right RPM motor on it that should work great.
#115
Nice, what thread is on the screw. ? You can come and use my lathe any time, but I'm in Toronto......
#116
Yes, this is really nicely built but I have a question that I hope wasn't already discussed.
Will this area be sealed up against dirt and exposure? |
#117
Looks good. Is it the same thread as the Servonaut screw drives?
#118
https://www.servocity.com/lead-screws https://www.servocity.com/8mm-4-start-hub |
#119
Thanks for the links Kent!
8mm per rev movement, that is very nice. I bookmarked that one for sure. I'm really getting to like Servocity. |
#120
I have started to go through all there stuff to get ideas on what might work for us. I've bought a bunch of motors from them including the screw drive motor on this truck. The Crackerbox had a planetary motor set that I ended up modifying with a different motor mounted to the planetary, fun stuff!
| Currently Active Users Viewing This Thread: 59 (0 members and 59 guests) | |
| Thread Tools | |
| Display Modes | |
