Old 12-21-2010, 10:51 PM
pugs pugs is offline
Nice work and nice shop
Jeff
Old 12-21-2010, 11:06 PM
kerst's Avatar
kerst kerst is offline
Looks great!
Kerst
Old 12-22-2010, 12:43 AM
Henry, Look in my 1:1 topic but that's my kids toy I built him back in 97' It's just a little Struck Mini Dozer I modified to resemble a Cat D4C about 1/2 scale I added a hydraulic blade also.
Pugs, That's only about 1/4 of my shop, there's more back in the darkness. We have about 12,000 sq.ft.
Old 12-26-2010, 10:24 PM
I got a few pieces cut this weekend on the second or middle 30-3/4'' (41') boom section. I had to do some serious filing and sanding to remove the machine marks from the Tee chord sections too.
I could have gotten more done but had the urge to operate the machine with the temporary boom on for about 2+hrs
Some tubes cut for both sides
Old 12-27-2010, 12:40 PM
modelman modelman is offline
Looks like you are making some progress steve-are you pleased with the way the model works with the boom section on? Is it strong?
Old 12-28-2010, 11:31 AM
rc_farmer's Avatar
Master Builder
I would really like to see this model in person one day. Its gonna be an awsome model.
Giving up is not an option!!!
Rob
Old 12-28-2010, 11:52 PM
I can't try the first section yet. If anything I'm going to just wire tie it under the temporary boom for looks and to keep fingers from touching it while at the show. But to answer your question Tom, It is very strong so far, much stronger than the temporary one that's just tacked together 1/8''x1/2'' flat bar.Also the safety lines add needed strength to keep it from buckling. I am almost finished milling angles and notching the tubes on the second section. After that is done I have to work on those dreaded splice plates again that took so long on the first section.
Old 12-31-2010, 06:35 PM
More pieces this week. I have 66 done but still need 39 more for this section of boom.
Drilling the chord ends 224 holes total 0-80 to tap.on these
A nightmare of angles
Old 12-31-2010, 09:20 PM
Stuff's Avatar
Stuff Stuff is offline
very cool!
my YouTube is -
Subscribe!!
My Facebook -
Old 01-06-2011, 11:24 PM
I got the second section pretty much done this week on the 9W project.
Still need the 3rd section.
.040'' rivet detail
Fitting up the splice what a time consuming job this was trying to install all the 0-80 socket head screws
ready to solder
second splice
100' or 75'' scale boom
Old 01-07-2011, 12:18 AM
tracksntreadslou's Avatar
Wow Steve Looks awsome...So close to being done for the cabin fever and wish I could be there to see it in person..Im totaly impressed ...great work
Old 01-07-2011, 01:03 AM
You will have to come next year with all your forestry equipment . IH steve and I talked about having a stripping diorama starting with cutting trees then scrape the topsoil off and start removing overburden down to a scale coal bed to load out I was saying around here in the past, the coal co's just push all the trees into the pit and cover them up with a D11
Old 01-07-2011, 01:17 AM
Stuff's Avatar
that's just crazy!!
my YouTube is -
Subscribe!!
My Facebook -
Old 01-07-2011, 12:09 PM
Looking great! hard to believe it has to get bigger yet.
Jeff
Old 01-07-2011, 01:28 PM
D8R D8R is offline
Fantastic work Steve, looking forward to see it finished. Is everything done inside, drums, brakes.....?
what´s the capacity on bucket?
Dan
Old 01-07-2011, 02:10 PM
JAMMER JAMMER is offline
Thumbs up Re: 1/16 Bucyrus-Monighan Walking Dragline
Steve great job looking forward to seeing it next week. Ed
Old 01-07-2011, 04:24 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
All that brass!!!! What a monster!! Hope to see it next week!
Lynn
Thanks again everybody.
Dan
I need parking brakes for the load drum and walking gear. Now I know more about RC I can figure this out. I wasn't sure If I should use air but I guess a servo is the easiest. Not sure the exact capacity of the bucket.
Does anybody know of a source for lighting? I want some big spot lights on the boom. I was thinking of buying Mini Maglite reflectors and build my own using their Kypton bulbs. I found I site that has model boat spot lights. I may get one and see how it works.
Old 01-07-2011, 04:46 PM
D8R D8R is offline
On my model I will try using Plexi cut to size, drill a hole on rear and put a white LED.
The Plexi was bought as scrap at local dealer, LED´s are 5 for $4. Plexi comes in different sizes, sheets, rods, I use 1" sheet (part of) and cut with bandsaw.
My LED´s are 3,2v 20mA, 2 connected togheter can be runned on reciver battery.
The brass strip will be used as guards outside lamps (on CAT models).
Dan
Old 01-07-2011, 08:07 PM
Well Steve have you got it all packaged up for York next week? I will see you there. Ed
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
