Old 04-04-2017, 12:09 AM
Northern Farmer's Avatar
Default Re: rc4wd 870k loader
For comparison here's the older back panel
Old 04-04-2017, 06:31 AM
I got that new version and yes, it does not have the fan. Also, I think maybe the battery compartment is a different size now. It seems to allow more standard sized batteries.
I bought this one, and it fits very nicely (143x51x28mm) and is quite cheap:
ZIPPY Flightmax 5800mAh 3S1P 30C
It fits very snugly. I don't think the battery could be any bigger in any dimension. Especially the width. I don't think you could squeeze 29mm in there unless you moved some of the plastic straps.
I replaced the bullet connector with XT60, but you can also buy an adapter with wire or without:
- Adapter with wire
- Adapter without wire
Best regards,
Stein :-)
Old 04-04-2017, 08:24 AM
lenny lenny is offline
lenny is on a distinguished road
that would figure, I placed my order mid February so I wonder what style engine cover I'll get. rather the older style to be honest. (newer looks a lil case-ish) Good info on that battery as well.
Old 04-06-2017, 12:50 AM
I like the new rear panel. I personally would replace the red lenses with some clear one's and put the reverse lights there with a slow vehicle triangle on the back
Old 04-08-2017, 09:39 AM
well I'm happy to report fed-ex spared my loader as it arrived perfectly. No wood just cardboard and foam packing, box gave me a little scare as it took some hits now ofcorse I just get a message the battery I ordered is out of stock so the torture continues. Now its just taunting me.. working on photobucket to upload some pics
Old 04-08-2017, 10:46 AM
That gives you time to do a one over. Check all your screws and connections to make sure they are tight. Also check your terminal block to make sure nothing is loose, as well as your RX connections. Looking forward to the pics!
Old 04-08-2017, 11:00 AM
I was thinking the same thing.. was just going thru the kit and not seeing the body for the waring becon??? just led bulbs with leads no base or dome
Old 04-08-2017, 03:15 PM
yep got shorted the becon light package..I received 18 bulbs and theres18 mounting holes on the machine. looks like a fun install to lots of tight spots. dont make sense to me not to offer the install at the time of build..
Old 04-09-2017, 01:01 AM
Nothing else it gets you to know your machine. Running those lights will require some stuff taken apart and seeing the "guts" to it.
Old 04-09-2017, 03:07 PM
looks like cab removal,rear cover and exhaust platform. and sure of plenty others.would like to run it a few times before tearing it down for light install and inspect for any issues. Shipping only very minimal oil from the vent line leaked. so I'll top it off run it thru it paces and change. clear line from tank to pump shows golden oil so should get thru some testing before a flush, if and when the battery gets here.. pure torture.. I'm not so hot for the radio kinda looks a little toy-ish but main concern was that it got here in one piece and I'll take that..
Old 04-11-2017, 04:51 AM
Thought of you Lenny when I saw this video
https://youtu.be/FIqWjSum2dQ
Old 04-11-2017, 05:01 AM
Thumbs up Re: rc4wd 870k loader
Gotta love the commentary
https://youtu.be/wT_bRjRZ23Y
Old 04-11-2017, 10:24 PM
ya never know what goes on in foreign parking garages.. yet another night she sits powerless. But on the plus side my new dura conveyor showed up, some assembly required sounds about right.
Old 04-12-2017, 02:03 PM
mitschka's Avatar
mitschka mitschka is offline
mitschka is on a distinguished road
have fun with the cool Toy
https://youtu.be/OO7XUgIN4G8
regards Marcel from Switzerand
here you find my models
Old 04-12-2017, 10:05 PM
going to a long night.. but in a good way, my battery got here early. still figuring out the whole lipo charger tested batt out of the box at 12.2 did a quick test of sound only, worked as it should for a minute then shut down and restarted so if its like the m.f.u on the charger she goes.
Old 04-12-2017, 10:40 PM
Yeah I recommend selecting a balance charge if you have the option on your charger. Every cell gets an even charge this way. Check youtube for help videos, there's most likely a video about your charger.
Old 04-12-2017, 11:31 PM
well there goes that idea, got the battery all juiced up and bang-o.. crap sound quality followed by no sound at all.. somthing loose, a good love tap to the cab and I get a lil tease. but everything else is going great. with some of the shipping horrors ive heard with r/c machines ill take a crapped out sound kit any day. sound or not i still love it.
Old 04-13-2017, 09:34 AM
Probably just a loose connection.
Old 04-13-2017, 09:55 PM
yep the leads to the speaker itslef are loose. easy fix. I would like to swap steering and tilt. anyone know which channel steer and tilt are on? to keep me from pulling one at a time, as i received no info on this radio or any paperwork for that matter.
Old 04-13-2017, 10:09 PM
Here's the wiring diagram for the loader. Steering is channel 1 and I believe tilt represented by "dump bed" channel 4.
