Old 06-07-2017, 02:51 PM
wolfen99's Avatar
wolfen99 wolfen99 is offline
wolfen99 is on a distinguished road
Default another newbie king hauler
This is my first build of a tamiya semi truck, have been building tanks but I needed a change, also in the process of changing a tamiya flatbed trailer to a spread axle, just waiting for the parts to come in.
Old 06-07-2017, 03:26 PM
wolfen99's Avatar
Default Re: another newbie king hauler
tried posting pics but cant seem to do it.
Old 06-07-2017, 03:33 PM
wolfen99's Avatar
Old 06-07-2017, 03:35 PM
wolfen99's Avatar
Old 06-07-2017, 05:41 PM
wolfen99's Avatar
I do have a question about the distance between the two axles to make it a spread axle if anybody knows that, thanks. just need the measurement from the front hub to the back hub.
Old 06-07-2017, 06:04 PM
wolfen99's Avatar
http://i61.photobucket.com/albums/h4...ps6jwxohpw.jpg
Old 06-07-2017, 06:08 PM
wolfen99's Avatar
Old 06-07-2017, 06:15 PM
That's a real nice looking truck so far
Old 06-07-2017, 09:14 PM
wolfen99's Avatar
thanks for posting the trailer pic, I was able to do the first two but couldnt get that one to post. P.S.
I brought the front axle back just a little, its about seven inches from hub to hub.
Old 06-07-2017, 10:17 PM
wolfen99's Avatar
did a little more work tonight.
Old 06-08-2017, 01:26 AM
avel avel is offline
Under the federal B formula, the axles must be 10 feet apart (though in practice they are placed 10 feet, 1 inch apart just to be safe for the times when a zealous enforcement officer measures that distance with a tape).With the "10-1" spread, each axle is considered independent, and can carry up to 20,000 pounds, ...
Youtube username iamaman27
Old 06-08-2017, 10:48 AM
wolfen99's Avatar
yep, use to drive for several companies that used spread axle trailers, tho I miss driving sometimes, I like being home.
Old 06-08-2017, 01:19 PM
FabOne's Avatar
FabOne FabOne is offline
Looks GOOD!
Keep posting.
-Terry
FabOne
NW Ohio
Old 06-08-2017, 03:26 PM
wolfen99's Avatar
Im waiting on a few more things to get here, putting super wides on the front, still need to get the legs for the trailer and looking for a tool box for the trailer and headache rack for the truck.
Old 06-13-2017, 03:45 PM
wolfen99's Avatar
update on the trailer...
Old 06-17-2017, 12:53 AM
wolfen99's Avatar
finished installing my amber beacon light.
Old 06-17-2017, 12:55 AM
wolfen99's Avatar
Specs on the light in-case anybody is looking for one.
These bars have 16 LED's in 4 sets of 4, each pair of LED sets ( Left and Right) flash in synchronised patterns (9 patterns). The flashing sequence is selected by two pushbuttons (one for front and one for the rear). The forward and rear pairs can be set separatley but the units can be modified to be controlled by a single button.
The case is of rounded form top front and rear, top and sides are silver/grey , front and rear are clear.
The beacon comes supplied with a connector for a 9Volt battery pack but will run from approx 3 volts to 12 volts.
Specifications:
Length:115mm
width: 25mm
height: 6mm
working voltage : approx 3 to 12 volts
Old 06-17-2017, 05:04 AM
blitzk's Avatar
blitzk blitzk is offline
blitzk is on a distinguished road
That's a sweet looking rig you have!!! Where did you get your light bar from? I have a couple of them but could use another one. How do you wire them to one switch? Do you just join the wires from one to the other?
Old 06-17-2017, 07:08 PM
wolfen99's Avatar
heres where I got the lightbar from, It still has the two switches that control the front lights and the back, I haven't change them yet. but you can splice them together to work off of one switch. there is a power switch that's located by where the 9 volt hooks up, then there are two button switches that control the functions on the front and rear lights. I found the L shape bracket in my junk drawer.
http://www.ebay.com/itm/291324232459...%3AMEBIDX%3AIT
Old 06-17-2017, 07:14 PM
wolfen99's Avatar
Im thinking about putting a headache rack on it but it seems that it would make it more difficult to get to the battery. I would have to keep taking the body off to get to the battery.
