Old 11-25-2013, 06:58 AM
Brel's Avatar
Brel Brel is offline
Default Re: Robbe, Linde H50 fork lift truck
540-man
as for the tilt on the mast, I broke the original Robbe servo horn set up by over loading it, so I replace it with a small servo arm and replaced the rod that screws into the clevis that fits onto the mast and kept adjusting it until I got it to what it is now
Old 11-25-2013, 11:36 AM
Brel's Avatar
540-MAN, Here is a shot of the tilt servo showing what I did to replace the original Robbe servo horn
Old 11-26-2013, 07:29 AM
540-MAN's Avatar
540-MAN 540-MAN is offline
540-MAN is on a distinguished road
Thanks Brel ill have to have a look at mine and see what I can do with it to make it to have better tilt.
Old 11-26-2013, 08:26 AM
Brel's Avatar
glad to help Mate, I had mine apart to take the picture of the tilt servo and rod and whilst I had it apart I moved the motor away from the gears slightly and used a piece of paper to space the gears before I re-tightened the screws and it seams to have reduced the racket the gears make slightly
Old 01-02-2017, 06:42 PM
Brel's Avatar
A short video of the Robbe Linde H50 FLT unloading my Scania R620 and flatbed semi trailer
https://youtu.be/c02ICjiK11E
Old 10-20-2017, 02:48 AM
Brel's Avatar
this is a repost of part of this topic showing the state of the FLT at the moment
I decided to update the electronics in the FLT and fitted a Servonaut S22 ESC and a Servonaut MFX for the lift motor. The S22 has outputs for brake and reversing lights, which have also been fitted using 3mm LEDs and resistors
It has only taken me 5 years to fit the reversing and brake lights
Old 10-21-2017, 01:02 AM
Awesome lift! 3d printed skid?
Old 10-21-2017, 04:56 PM
Job well done getting all the electronics fitted.
Old 10-21-2017, 08:38 PM
Brel's Avatar
If you mean the blue thing on the forks, it is a hand made wooden pallet, I measured a Blue CHEP pallet at work and did a rough drawing on the orrientation of the blocks to make the pallet myself out of wood because they look better than a plastic one
here is a picture of an unpainted one on the forks of the truck
Old 10-21-2017, 08:40 PM
Brel's Avatar
thank you my friend
Old 10-22-2017, 02:45 PM
Do you have pics showing how you made the steering work? If I'm not mistaken isn't this a static Bruder model that you've converted to RC?
Old 10-22-2017, 08:57 PM
Brel's Avatar
you are mistaken my friend about this Robbe Linde H50 fork lift truck being a Bruder conversion,
it is a full rc kit made by Robbe and not by Bruder, then after assembling the kit and painting some of the orange parts black, I added the electonics and swapped out the plastic steering axle for an alminium/aluminum one that I found on the internet
Old 10-22-2017, 09:00 PM
Originally Posted by Brel View Post
you are mistaken my friend, as the title of this topic says "Robbe, Linde H50 fork lift truck"
it is a full rc kit made by Robbe, and not by Bruder
Thanks for the info. Do they still offer this for sale? I've found a few on Ebay, but they're well over 300.ooUSD each
Old 10-22-2017, 09:05 PM
The one I've found, on Ebay, it's a Carson,
$281.6o USD PLUS $92.26 USD for shipping
https://www.ebay.com/itm/C907093-CAR...4AAOSw3YJZSimn
Old 10-22-2017, 09:11 PM
Brel's Avatar
The Robbe model is rarer than rocking horse poop
go for the carson one they are just as good
Old 10-22-2017, 11:04 PM
Right on. If you ask me the bare wood looks great too.
Old 10-23-2017, 06:33 AM
Brel's Avatar
video of the truck, unloading my Tamiya flatbed trailer built from the reefer kit
Tractor unit Tamiya Scania 6*4 R620,
Old 10-23-2017, 12:26 PM
Rimrock Rimrock is offline
I guess that the Robbe truck is more powerful? have read somewhere that the Carson lifts somthing like 0.2 kg, while the Robbe 1 kg. what's correct?)
Soyland Industrier
Old 10-25-2017, 04:06 AM
Brel's Avatar
I don't know anything about the Carson truck, the Robbe truck will lift about 1.2 KG
Old 10-28-2017, 04:22 AM
Alright, 1.2kg is very good. -The Carson have much lower capasatiy, so there is a huge difference between those trucks, even they look similar. Sadly the Robbe truck is no longer in production.
Soyland Industrier
