Old 11-03-2017, 09:20 PM
bigpipespete bigpipespete is offline
bigpipespete is on a distinguished road
Default King Hauler
Hey guys , just wondering if anyone else has this problem with reverse on their King Hauler. In forward the truck can be started off slow or fast , but when I reverse the truck you better have lots of room cause it is full throttle . I added a dump box from RCP57 so the guy at the hobby store installed an HPI Racing esc and it uses the Futaba 2.4GHz S-fhss system. Otherwise its stock. Any ideas how I can slow it down would be appreciated, thanks.
Old 11-04-2017, 12:07 AM
Trucker Al's Avatar
Trucker Al Trucker Al is offline
Trucker Al is on a distinguished road
Default Re: King Hauler
Get a different ESC or re-calibrate the one you have..
Old 11-04-2017, 11:50 AM
X2. Sounds like you have an ESC setup for racing in a dump truck. You need to reprogram the one you have or buy something really cheap like the $10USD ones that Hobbyking sells. They work great for the truck and dump bed and don't break the bank either.
Old 11-04-2017, 06:34 PM
Northern Farmer's Avatar
^What Reg said
https://hobbyking.com/en_us/hobbykin...d-car-esc.html
Old 11-04-2017, 08:28 PM
Thanks guys , I will see if I can re-calibrate this one if not I will buy a cheapo.
Old 11-05-2017, 11:56 AM
TRUCKMAKER's Avatar
People think they have to have high end stuff for these trucks, it just creates problems. I too use the $10 dollar hobbyking esc’s . Haven’t toasted one yet. Also make sure your trims are set correctly, I have a habit of bumping mine.
Old 11-05-2017, 02:46 PM
Mustang46555 Mustang46555 is offline
Mustang46555 is on a distinguished road
I run old Novak's that nobody in racing or crawling uses any more. Dime a dozen on flea bay and work just fine. As Kent said, check your trims, they are easy to bump.
Old 11-10-2017, 07:13 PM
thebat's Avatar
thebat thebat is offline
thebat is on a distinguished road
another option is the hobbywing 1050 esc there 20 bucks and can run lipo both 2 and 3 cell it is what i run in my king hauler on a 2s pack works liek a charm an have two other of these escs in scale trial trucks no issues at all.
Zach The Bat Flowe
Keep On Rollin.
Old 11-10-2017, 08:42 PM
Ive got a lot to learn about the electronics in this hobby, if anyone on here is from the Vancouver area or knows of someone that is and doesn't mind teaching , id be happy to speak to you. Thanks
