#61
So the rollers need enough clearance to roll but not to tight not to loose . Hmmmm
#62
Yes. When we adjusted hook rollers, we'd lay the boom straight out (sometimes with weight on it) to tilt house forward, then measure clearance at top of front rollers and at bottom of rear rollers. Since rollers are tapered, adding or removing shaft shims would push them toward or let them pull away from the center shaft, altering the clearance between roller and circle flange.
Big iron is awesome! |
#63
Ok now just have to build that in 1/14 scale . Thanks Ken
#64
Nice work! I like seeing these scratch built projects come to life.
#65
Thank you.
I had some free time over the weekend and I was able to the roof hatch on the crane housing done. ![]() ![]() On a side note. I got the lathe running and bought a quick change tool post, so now all I need to get is some tooling and a drill chuck and center, and I will be able to start machining the swing ring. Shawn. |
#66
I wish I had skills enough to do scratch built styrene work like that!
#67
Looks great . I made my floor and stabilizers
#68
And my pic didn’t come in sorry (frustrated )
#69
Have you tried using a image hosting site?
Shawn |
#70
You have a drawing for this piece ? Would you share it ? Mike
#72
I've posted this in the past. Is this of any help? I have more if needed.
#73
Yes I have seen these , but I’m looking for more dimensions. And I thought Jared had a personal drawing of the turntable . Reading these engineer drawing is not for the faint of heart . Thanks Mike
#74
Usually I enlarge or reduce these drawings to fit my use. The design is pretty much the same throughout the line of these machines.
I may be able to dig a little deeper in my books and find more on those rollers. |
#75
Thanks for posting those drawings, i think i can find some use in them for my Michigan dragline.
#76
![]() ![]() I hope this helps you. Shawn |
#77
Thanks for this it does help . I was using my guesstimated size of 4 inches , so that was close to 3.96.
#78
A small bit of progress on the crane. I made this service hatch, I don't know what it's supposed access on the real machine but it should come in handy to access the winch motors or a battery.
![]() ![]() Shawn |
#79
Nice
#80
What color have you picked , and do you plan on making it look like new or an old tired machine like in that picture ?
| Currently Active Users Viewing This Thread: 16 (0 members and 16 guests) | |
| Thread Tools | |
| Display Modes | |
