my D11 dozer my dad and I built this past winter 130 pounds blade is 24 inches wide just to give an idea of size. the Cat still has custom decals and lights that have yet to be installed . the cab over semi seen in the one pic is a full custom (my dad made the cab). the two dump boxes are also homemade minus the chassis.
Awesome models!
Big iron is awesome! |
wow! nice work, that thing looks like a beast
Thanks it was alot of work and a lot of research to get it this far .Its currently being modified to have full blade fuction i also just swapped out the 12 volt agm battery for some 14.8 16000mah lipo batteries now i can go for 1.5 hours on a single charge !
Were did you get the 16000 mah lipo batteries?
Were did you get the 16000 mah lipo batteries ?
Just a website called hobbyking was 64 dollars cad so bought 2 seem to work just fine
Would anyone know who to talk to about a planetary gear reduction fot the drives would be nice to use a larger sprocket ?
I LOVE IT! Thanks for the build pics that you included with it. That machine looks good
I can post more pictures in its early build stages later on this weekend when i get infront of a computer .
Just a few more build pics as well as the lights that were just put on decals will be the finishing touch.
how long did the 12 volt battery last im building one now using a car battery nicebuild looks awsome how does it well does it push in the dirt jim
I used a agm 12 volt 18 ah agm battery lasted about 45 min but had very low power to push dirt it was fine to push snow but that's about it .what I found is that when I test the voltage at each motor with a sabertooth 2x25 I was only getting 6.7 volts to a motor . I would recommend to find some large higher voltage lipos turned my dozer from being a turd in the dirt to having all the power I need plus it last twice as long with out such a drop in power as the battery gets low.
It will easily push a full blade of dirt( about 24 inch blade) easily but that's with the lipo 14.8s with the lead acid or agm 12 volt it struggled I would recommend a gear reduction just to slow it down a bit
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Thread Tools | |
| Display Modes | |
