Old 10-28-2018, 08:21 AM
Default Re: CAT 14M3 Motor Grader
Today I did some lathe work for a change. I machined the end caps for the steering cylinders. The inside diameter is 5 mm, so the tools are quite small.
I took a video of it and I will load it to Youtube.
Old 11-03-2018, 11:29 AM
That's awesome! I'd love to have the tools, equipment, & know how to build things like you do!
Old 11-10-2018, 10:12 AM
Turan5561 Turan5561 is offline
Turan5561 is on a distinguished road
I read the other project excitedly over and over again. I follow this project with no patience. how do you draw the drawings.how do you do the scaling. where do you get the pictures inspired by.I'm waiting for your answer. I want to draw too. I would be very happy if you give me information about what I'm looking at. do you help me find pictures of real pieces? Thank you
Old 11-10-2018, 12:04 PM
I got the tires from Premacon and I'm drawing the rims at the moment. I hope I can start machining them tomorrow.
Old 11-11-2018, 05:10 AM
Smile Re: CAT 14M3 Motor Grader
First operation
Old 11-17-2018, 07:44 AM
The rims are done
Old 11-24-2018, 06:18 AM
I got the grader on it's wheels
Old 11-24-2018, 01:03 PM
This build already looks AMAZING!
Old 11-25-2018, 03:36 AM
jack van's Avatar
jack van jack van is offline
will you make it 6 wheel drive and also maybe add a wing or 2 hehe and front blade lol sorry i am soo greedy
Old 12-02-2018, 11:11 AM
I made a few parts under the cab
Old 12-07-2018, 10:35 AM
Got something done today. I made the brackets that the blade cylinder arms attach.
Old 12-07-2018, 05:38 PM
Cooper's Avatar
Cooper Cooper is offline
Do you use and glue on aluminum or weld? I’ve been finding a lot of uses for some of the adhesives industry offers. And some of the stuff is more effective than welding. Depending on the design and application. Parts are looking good!! Build is amazing!!
Old 12-07-2018, 05:47 PM
Tunnelmaynia Tunnelmaynia is offline
Tunnelmaynia is on a distinguished road
Hello hemi1966,
I am very impressed with your work. I am a fellow machinist and I also use fusion 360 for my CAD and CAM. I want to start a build of my own but the biggest obstacle finding scale drawings or even the 1:1 size to be able to scale down. Can you please share where you are getting your dimensions from. Also some photos of your machines and maybe some work holding. I really like the idea of building them yourself versus buying a manufactured version. Thank you in advance for the help with the drawing sources. Jeremy.
Old 12-07-2018, 11:59 PM
Roninnater Roninnater is offline
Roninnater is on a distinguished road
This is absolutely amazing!!! I can’t wait to see more progress of this fantastic project. I’m hoping to start my very first project. I am no where near such expertise as this but it sure is inspiring.
Can’t wait to see what happens next!
Old 12-08-2018, 09:16 AM
ederson's Avatar
ederson ederson is offline
ederson is on a distinguished road
show to gostando de ver seu projeto
Old 12-09-2018, 03:19 AM
With this I have not use glue, but on some previous projects I have.
Old 12-09-2018, 04:15 AM
Originally Posted by Tunnelmaynia View Post
Hello hemi1966,
The big difficulty when making these is the lack of scale drawings
I first get a 1:50 scale die cast model of the object, with that you can get some measurement.
The machine brochure usually have some dimension drawings.
One place to look is also this: https://avspare.com/, there you can get some idea of the parts.
Drawing a part that is more complex often takes more time than actual machining. The following parts assembly I was drawing many, many, hours
Click my signature at the end of this message to get to my Youtube channel to see some machining videos.
Old 12-10-2018, 04:52 PM
Hemi1966
Thank you for the reply. I hadn't thought about scaling up. I was afraid of the dimension from the smaller die-cast models being to far off. I will give it a go and start drawing some things and assembling the 3d components in fusion. Thanks again.
Old 12-11-2018, 11:53 AM
Hemi1966
Dimensions of smaller details that are impossible to cast in small scale might be slightly off, but most dimensions are correct enough.
Old 12-14-2018, 09:00 AM
DWA2469 DWA2469 is offline
DWA2469 is on a distinguished road
Hemi your work is second to none, I wish I possessed the skills and tools necessary to accomplish this.
