Old 01-05-2019, 07:27 AM
ChILd_ReBoRn ChILd_ReBoRn is offline
ChILd_ReBoRn is on a distinguished road
Default Battery capacity. What's nominal?
So, since I'm trying to built a rc vehicle on a budget, I decided to build my own battery. Not sure how "big" should it be. I've ordered the PCB, and I think 3000mAh should be enough (3S). I have 2 motors and 2 servos. The dozer is about 30cm big, 6 lbs max. Will it be able to have a 30 min play cycle? Or should I just try to cram in 3S2P battery? That would be massive 6000mAh, more expensive, bulky, PCB won't work for balancing and it would be heavy. Even charging would take a long time..
I'm inclined to 3000mAh, but open to suggestions.
Ty
Old 01-05-2019, 03:15 PM
Default Re: Battery capacity. What's nominal?
Buy two 3000mah
Old 01-05-2019, 04:24 PM
And swap them when one is depleted?
I have some 18650 cells lying about, I'll solder them in 3S configuration and use it for testing purposes. If they suffice, I'll order a dedicated LiPo pack(s).
Old 01-05-2019, 07:43 PM
The 18650 batteries are not designed to handle the discharge rate(s) that may be put on them. For a test they should work one or two times.
As Joe said TWO 3000MAH batteries is good. That way you can have one on the charger while you're running the other.
Old 01-06-2019, 05:23 AM
ok.. something new learned. 3000mAh going on the shopping list
Old 01-06-2019, 05:19 PM
nes999 nes999 is offline
nes999 is on a distinguished road
I sort of feel my like 10,000 Mah will be severe overkill when it arrives...
Old 01-06-2019, 07:09 PM
Bo Wallen's Avatar
Lightbulb Re: Battery capacity. What's nominal?
Lol. Three times the runtime wouldn't. hurt Or?
Old 01-06-2019, 08:10 PM
frizzen frizzen is online now
3000 mAh should be plenty.
Do you need 3s or would 2s voltage still get what you need?
Old 01-07-2019, 06:57 AM
Nah, I ordered 3S. 7,4V would be to slow
Old 01-07-2019, 09:12 PM
10,000MAH batteries are AWESOME! I run it for the RC4WD 4200XL Excavator, as well as in the Faroe loader. I can run a half days work on ONE battery. Then I have to resort to the back up battery, a 6,800MAH battery to finish the remainder of the day....Well ALMOST the remainder of the day.
Old 01-07-2019, 11:24 PM
Cooper's Avatar
Cooper Cooper is offline
You guys would be better to use two separate batteries and just plug them together (parallel) , when a is 3s2p. You have six cells. You never truly get a balanced charge (that's where potential problem occur with lipos) on all cells. Yes you have two batteries verses one but you also have the ability to maintain two separate batteries. And if you are "making " your own packs keep in mind they are not electrical storage devices but mini chemical reactors, store appropriately.
Just my .02$ , I rarely read directions and am always doing what I'm told not to but when potential injury, or fire results can happen better safe than sorry.
Old 01-08-2019, 01:13 AM
I agree with you about balancing problems with 3s2p. 10kmAh is a serious overkill and logistic problem for me, so it is out of the question..
Old 01-08-2019, 12:54 PM
Yeah mine is just 7.4v for so shouldnt be much of an issue balancing wise.
Old 01-11-2019, 09:26 PM
tylor tylor is offline
tylor is on a distinguished road
can lipo battery be used on this truck? such as 7.4 v lipo battery from some brand.
Old 01-12-2019, 01:02 AM
Yes, 2S LiPo batteries can be used in the Tamiya trucks.
