Old 02-03-2019, 10:26 AM
Default Re: CAT 14M3 Motor Grader
Got some more parts done for the drawbar
Old 02-08-2019, 05:06 PM
bobmorey bobmorey is offline
bobmorey is on a distinguished road
Hemi
Superb workmanship and really inspirational project. I have question on your homemade cylinders. Do you use a specific steel for the rod, ie precision ground drill rod, or regular steel? Also what type of oring? Silicone? Viton? I really want to try to make a working cylinder for a dozer.
Love the grader - masterpiece!
Best regards,
Bob
Old 02-08-2019, 05:15 PM
This build is AMAZING! This will be super cool when everything is done & this masterpiece is moving dirt.
Old 02-09-2019, 08:24 AM
Originally Posted by bobmorey View Post
Hemi
Best regards,
Bob
Thanks Bob.
For the rods I use 1.4021 stainless steel. I'm using both Nitrile and Viton o-rings.
Old 02-09-2019, 08:27 AM
I got the drawbar in place.
Old 02-10-2019, 06:51 AM
I made the blade lift cylinders today
Old 02-10-2019, 10:23 AM
Nice work as usual Ari!
Old 02-17-2019, 01:46 PM
BlackCat BlackCat is offline
BlackCat is on a distinguished road
Great job you are doing here Hemi ! May i ask what type/grade of aluminium you machine ? I want to use 6061-t6 for my project but maybe you have a better alternative ?
Old 02-18-2019, 11:56 AM
I'm mostly using 6061, but I also have some harder aluminium that I have no idea what it is.
Old 02-23-2019, 11:07 AM
I've been working with the circle gear, and I got it almost machined when it came loose off the chuck. I could not tighten the chuck very tight because the circle gear is not very thick. I was taking very moderate cuts and relatively slow speed, but it was not enough
I have to try again, and do the final operation with different mounting method.
Luckily some parts turn out decently.
Old 02-23-2019, 11:16 AM
That's a sad let down! The part looked like it would have been beautiful, before the catastrophe.
Old 02-23-2019, 12:32 PM
Bummer I know the feeling when a part comes out. I've had big parts that I'm getting paid for come out of my setups running the endmill across it making pretty tooth marks every 1/4" because I'm usually climb milling.
On your piece; Could you cast it in some of that Bismuth alloy?
If you don't know what that is, it's a soft lead type metal that melts in hot water.
Old 03-02-2019, 06:49 AM
Success on the second attempt
Old 03-02-2019, 01:07 PM
JAMMER JAMMER is offline
Excellent job Ari you are a real artist with your Graders. Ed
Old 03-02-2019, 03:06 PM
Glad it worked out for you second time around! Looks beautiful!
Old 03-03-2019, 07:50 AM
Thanks guys
I got the centershift cylinder and few brackets done.
On the last pictures you can see some extreme angles of the drawbar.
Old 03-09-2019, 01:15 PM
Not much machining done this weekend, I've been drawing the blade and other related parts
Old 03-10-2019, 11:01 AM
Griszaa Griszaa is offline
Griszaa is on a distinguished road
That is insane .....
Old 03-11-2019, 11:27 AM
Few parts for the blade side shift...
Old 03-11-2019, 04:34 PM
tracksntreadslou's Avatar
Nice work Ari ..3D cad can be very challenging at the best of times .your first grader build inspired me to build one as well..Your work blows me away .mine has been coming along fairly well and always trying to do some upgrades and details ..heres a vid of it doing some snow work ..
https://www.youtube.com/watch?v=JZTlPB4x5fs
