Old 12-22-2019, 02:51 PM
Default Re: CAT 14M3 Motor Grader
You maximized the paintbooth
Old 12-26-2019, 10:57 AM
I've been assembling the drawbar. I soon run out of hose, I "only" purchase 10 meters of it
Old 12-26-2019, 11:27 AM
ederson's Avatar
ederson ederson is offline
ederson is on a distinguished road
ta ficando muito bonito belo trabalho
Old 12-27-2019, 05:05 AM
Ho-ho-ho! hoses
Old 12-27-2019, 09:44 AM
Old 12-28-2019, 08:11 AM
No more hose left
Old 12-28-2019, 05:45 PM
Neat and tidy
Old 12-29-2019, 11:38 AM
I got the rear frame attached
Old 12-29-2019, 01:23 PM
Wow, deja vu, feels like I've been thru this before!
Looks amazing!
Old 12-29-2019, 01:44 PM
Looks amazing!
I've been having same kind of a feelings
Old 12-30-2019, 10:11 AM
Benni Benni is offline
Benni is on a distinguished road
Such a beautiful piece of art, and a bit of a headache I imagine.
Old 12-31-2019, 09:08 AM
So how did you mark the hoses so you know which two pair together?
Old 12-31-2019, 09:58 AM
Good question, and I'm glad that I was thinking that when I mounted the hoses to the brackets. Basically I drew a map of the bracket and marked which hose is in which hole, and I kept the same order all the way. There's 14 lines in 3 layers on the brackets, so it could be quite of a mess
Old 12-31-2019, 10:15 AM
I lifted the grader on it's wheels
Happy New Year 2020 !!!
Old 12-31-2019, 10:40 AM
JAMMER JAMMER is offline
that is a plumers nightmare. Ed
Old 12-31-2019, 11:30 PM
jack van's Avatar
jack van jack van is offline
wow that is a true work of art your abilities and workmanship are awsome got a question for you though what radio do you plan for this machine and how many channels will you need for basic use and will you have any extras will you have for spares like a wing or front blade this is the best model i have ever seen made including the Liebherr stuff the germans make you are a master of radio-controlled machines oh 1 more thing how many hours do you think you have in this when done do you think
Old 01-01-2020, 02:54 AM
Thanks man
I'm using Servonaut HS12 radio and it has 12 channels. I'm able to expand that to 16 channels. The hydraulics take 9 channels, and there's 1 spare for ripper or front plate etc.
Hard to say how many hours it take to finish, but I estimate that less than 100 h
Old 01-01-2020, 09:44 AM
So was that a lesson learned from the last grader, make a map this time around?
Do have any slider chs on that radio? Put for/rev on a ch like that to set one speed & use the joysticks solely to operate blade.
How many mixes do you have on that radio?
Old 01-01-2020, 10:17 AM
I think on the first one I routed all the lines separately from cylinder to the valve.
No sliders on the radio, but I can emulate sliders with two buttons.
If I understand correct there is no limit for the amount of mixes.
Old 01-01-2020, 12:13 PM
I made a front weight today. It really is quite heavy, all brass. It should help steering while grading
