Old 06-22-2020, 10:39 AM
Bo Wallen's Avatar
Lightbulb Re: KH Beam Hauler
[IMG]IMG_6197 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6219 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6217 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6220 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6218 by Bo Wallen, on Flickr[/IMG]
Old 06-22-2020, 10:41 PM
Bo Wallen's Avatar
Half Way There.
[IMG]IMG_6223 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6222 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6224 by Bo Wallen, on Flickr[/IMG]
WooHoo!
Old 06-23-2020, 06:59 PM
Default Re: KH Beam Hauler
Looking good, Bo!
Old 06-23-2020, 09:21 PM
That's a really sharp Merc outfit. Was it an old tamiya body, or Freddy custom?
Are the trailer tires supposed to have that much offset? Looks good either way.
Old 06-23-2020, 11:00 PM
Bo Wallen's Avatar
Thanks, Frizzen. Yes, Freddy cut that body and made it to a day cab, model short. The Trailer has the longer axles, 140mm. I think duals have 120mm if I remember right. After the Merc, I will rebuild the Trailer to extendable, the trombone type and more axles, of course.
Old 06-23-2020, 11:18 PM
Bo Wallen's Avatar
Exclamation Re: KH Beam Hauler
Some other stuff arrived. Let's do this.
[IMG]IMG_6226 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6233 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6232 by Bo Wallen, on Flickr[/IMG]
Out with the weak suspension.
[IMG]IMG_6234 by Bo Wallen, on Flickr[/IMG]
And push in the new.
[IMG]IMG_6236 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6239 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6237 by Bo Wallen, on Flickr[/IMG]
I am done for today, G Nite.
Old 06-24-2020, 03:33 PM
Bo Wallen's Avatar
Two Stacks are better than one.
[IMG]IMG_6241 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_6246 by Bo Wallen, on Flickr[/IMG]
Old 06-26-2020, 12:31 PM
Bo Wallen's Avatar
The steering mod. Is all done, The extreme short wheelbase makes this truck to turn sharp, very sharp.
[IMG]IMG_6248 by Bo Wallen, on Flickr[/IMG]
I also need to fit the Heavy Haul Push/pull couplings front and rear, and Plates has to relocate.
[IMG]IMG_6255 by Bo Wallen, on Flickr[/IMG]
Air tanks and "battery" box also in the works to be installed.
[IMG]IMG_6252 by Bo Wallen, on Flickr[/IMG]
More to follow.
Old 06-26-2020, 12:37 PM
Bo Wallen's Avatar
Oops! I forgot the beginning of the next build.
[IMG]IMG_6253 by Bo Wallen, on Flickr[/IMG]
Old 06-27-2020, 09:24 AM
NRS91 NRS91 is offline
NRS91 is on a distinguished road
Whats coming next Bo?
Thanks
Nick
Old 06-27-2020, 10:19 AM
Bo Wallen's Avatar
Talking Re: KH Beam Hauler
The plan is,
Old 06-28-2020, 02:00 PM
The plan is
ooo very nice! whole new fleet eh?
If you are looking for cheap tamiya based driven steer axle conversion kits then watch my store
Thanks
Nick
Old 07-01-2020, 10:24 AM
Bo Wallen's Avatar
Thanks, Nick. Yes, a slight extension to the fleet, Your front axles will be needed for two of the Benz. The Lesus is just garbage
Old 07-01-2020, 10:51 AM
I guess you dont have issues with the stock Tamiya rear axles?
Here is a sneak preview for you
Thanks
Nick
Old 07-01-2020, 09:33 PM
Bo Wallen's Avatar
Thumbs up Re: KH Beam Hauler
Thank You, Nick. I have a good feeling about your project. I will Have your product Incorporated in my fleet. The original Tamiya axles are right, and if they get tuned tight when built, they will last a long time. I have axles with far more than three hundred hours on them, still running smooth. So let's have the two current Mercedes on the bench run your front axles.
I am looking forward to working with you. Nick.
Old 07-01-2020, 09:45 PM
I currently have 1 pinion out of 6 which jumps out of mesh, it's a different design to the other 5 on the 8x8 so not sure where it's from but will add a circlip or washer between the gear and bearing then full testing can commence!
Thanks
Nick
Old 07-02-2020, 01:03 AM
Bo Wallen's Avatar
The Mesh is extremely important on casted gears; There is no shortcut at that.
However, Tamiya does not make metal parts in the house. Therefore the gearbox has two different pressure angles on the gears, Old standard and new. Witch makes the gear to go down faster than it would with the same pressure angles. Now Japan is a monoculture, so the boss does not know that, and a new gearbox or axles will not be on the horizon for some time. But the work so I stick with them.
Old 07-02-2020, 07:10 AM
Yea its very odd all the axles ive built so far have been spot on besides that one pinion that has free play but ill get it sorted!
Thanks
Nick
Old 07-15-2020, 04:52 PM
Bo Wallen's Avatar
Just came across this site again. Over Milion's views. https://www.youtube.com/watch?v=NNVn8fLy5Ro
Old 08-03-2020, 06:51 PM
Bo Wallen's Avatar
Today I started designing the solution for the weakest part in the gearbox, Hope it will work as good as I hope.
[IMG]IMG_6268 by Bo Wallen, on Flickr[/IMG]
Design and Machining, my self. Hardening outsourced.
[IMG]Screen Shot 2020-08-03 at 10.55.25 AM by Bo Wallen, on Flickr[/IMG]
