Old 09-18-2020, 09:01 PM
Cat966c Cat966c is offline
Default Huina servos disassembly
Hey all; long time no see ����‍♂️
I just got huina replacement servos screw drives for my loader (for the meantime—I just want to see it run, immediately ��) and I need to know how to take the “cylinder” off of the servo (I need to shorten it).
There’s a pin(?) that holds it on the servo, but how do I get it off?
Is it a lil screw???
Pls halp
Thanks ��
Old 09-19-2020, 07:21 PM
Default Re: Huina servos disassembly
Bump
Old 09-19-2020, 08:37 PM
Got any pics or a link or something so we can see what setup the new servos use?
Old 09-20-2020, 03:07 PM
They’re the ones huina sell.
Old 09-20-2020, 03:11 PM
They look like this:
https://www.amazon.com/Vaorwne-Chann.../dp/B07XK19F77
Old 09-20-2020, 03:13 PM
I need to know how to get those little pins out
Old 09-20-2020, 04:46 PM
From the amazon pics, they look like probably Tapered Pins?
So support the shaft with something that leaves room for the pin to come out. Small side of pin facing up, select a pin-punch just small enough to fit, tap out pin with small hammer. It should start moving after a couple taps.
If it's just a Roll Pin, or a Straight Pin you won't need to determine a small end on it, it can go out either way
Old 09-20-2020, 10:19 PM
Hey thanks!
Question(s) though:
How do I determine which is the small side?
What do you mean support the shaft?
What kind of pin punch?
Old 09-21-2020, 05:02 PM
One end of the pin will look slightly smaller as you look at the side of the shaft, you might need a magnifying glass to tell sometimes.
I keep a scrap piece of 2x4 handy with a hole drilled drilled in it, when I need to drive a pin or something out I just put it over the hole and rest the shaft on the 2x4 and tap on it..
A simple pin punch https://www.amazon.com/Mayhew-Pro-21.../dp/B00065UJWS
It's used to drive out ...pins...
Old 09-23-2020, 06:46 PM
Hey, thanks!
Great!
So can the pin go back in??
Old 09-23-2020, 06:47 PM
And can it go back in a different hole? Like one I drilled myself?
Old 09-23-2020, 07:33 PM
If you've got them, something like a Dial caliper or Micrometer are easier ways to tell if it tapers. It would be subtle.
Pins can be reused as long as they fit tightly.
If it's a tapered pin, they are much happier with a tapered hole so that it has full contact everywhere. Straight holes with taper pin give a lot of contact pressure in 1 or 2 spots, then with use something deforms and the joint loosens up.
Old 09-24-2020, 12:12 AM
Hmmmmm
I have an old slide caliper
So if it’s tapered, it’ll go back in?
Do I just tap it in the same way?
Old 09-24-2020, 05:47 PM
If you put the small end of the pin in the large opening in the rod....just tap "gently" it shouldn't need a lot of force.
If you don't have one look at Harbor Freight at the digital calipers $20 I use it all the time money well spent....
Old 09-25-2020, 07:32 PM
Yes, I know ����‍♂️ I know it’s well worth it and I’ve been meaning to Get one but I keep getting sucked into this black hole (lol #helpme)
Ah, so all I have to do to get the pin back in is just tap it in the same way I tapped it out?
And also: would using the same diameter regular screw and nut work?
Old 09-26-2020, 09:54 AM
Not sure how your going to use them so maybe yes... maybe no... If the nut and bolt don't interfere with how you plan to use it then sure...I would try to make the pin work... again it it's not tapered then it's easy.....sometimes you have to try stuff to see if it will work. I try to use the least destructive method possible so I can fall back to the original design if I have to and I try not to experiment on expensive or hard to get things...lol
Old 09-26-2020, 10:26 PM
I’m just planning to use the bolt and nut in place of the pin, because I plan to shorten the cylinder that the pin goes in and I won’t be able to reuse the hole and pin ��‍♂️
