Old 02-06-2024, 02:06 AM
Default Re: 1/10 caterpillar 140h motor grader 3d printed
Originally Posted by Zabco View Post
Very impressive piece of work, will really be interesting to see in in action when complete. Like the idea of using the plywood to strengthen the structure. What kind of adhesive did you use to bond the PLA to the wood?
I remember i used epoxy so i can still set and then clamp it, and then a little CA glue on the edges to set it firmly.
Old 02-06-2024, 02:13 PM
too many hours of cad work...
Old 02-07-2024, 06:24 PM
What are you using for your CAD? I'm looking for something that isn't a subscription.
I don't mind paying for a license, but I'd rather have a perpetual license instead of something that can be turned off if they feel like it. (Like Autodesk, Draftsight, and Designspark all did.)
Old 02-10-2024, 12:47 PM
I have been modeling with Autocad for all my projects since i started using a printer so im quite comfortable with it. got it from a friend who lets me use the license, but i dont the use the online connectivity, quite annoying.
Old 02-10-2024, 07:36 PM
You might be interested in Atom 3D by Alibre. I'm with you on wanting to own my software and I hate these 'cloud' based programs. I've been using Atom 3D for over a decade now and really like it. Once you buy it, you own it. This includes any upgrades for a year that they may put out. If the year has expired and you want to install an upgrade it's only $50 for another year. But you don't have to upgrade if you don't want, the program is still yours and keeps working. The program is currently selling for $199 but they have a 20% off deal going through the end of this month. Atom is not as full featured as their 'pro' and 'expert' programs but they are much more expensive and subscription based. The only thing really lacking in Atom that I wished it had is sheet metal layout. But I still remember enough of my high school drafting class to be able to manually layout the work I need.
Old 02-16-2024, 10:15 AM
carp carp is offline
this is great, how did you design the bogie drive? gear motor gear train or chain drive? always interested to see pictures of how others have done it. Also attaching the bogie to the diff output?
you can pick up a solidworks connected for $49 a year which is everything bar solidworks motion which you probably wont need, failing that fusion 360 is free
Old 02-16-2024, 05:07 PM
This is how it looks like inside the axle casing...I use a #35 steel chain that wraps around both wheel axles sprocket and goes at the bottom of the center sprocket. I printed the sprockets with brass axles so i would just strip or slip when under heavy load. easy to repair than having to repair a stripped gearbox. the center sprocket is directly attached with a flange to the double output shaft geared motor, so it is all locked up, no center differential gears...
Old 02-17-2024, 03:17 AM
Is there some type of bearing inside those green shells for the sprocket/axle shafts? Or are the shells 3D printed bearings?
Old 02-17-2024, 01:01 PM
Yup, 8x16x5 steel bearings on both end casing so 6 bearings in that bogey axle.
Old 03-18-2024, 03:47 AM
Cab interior almost done, except the pedals, rear view mirror and cooling fan...
Old 03-18-2024, 03:50 PM
Glad you showed a close-up of the cab... I want to do a Nylint grader at some point so I was looking for some cab detail....Mine won't be that detailed but I'll add something to help it out a little...
Old 03-18-2024, 05:27 PM
oh those vintage metal toys, i remember seeing one when i was a kid at some friends house, but they were locked in a glass cabinet, so only for the eyes... that is where my love for miniature stuff started, cant buy one, so i built my own toys...lol
Old 03-19-2024, 03:25 PM
pedals and cooling fan are installed...
Old 03-20-2024, 01:44 PM
Either that thing is huge or your printer prints some tiny tiny stuff....
Loving the details ...
Old 03-20-2024, 10:06 PM
Haha, thanks, its quite huge as it is exactly 1/10th of the full size rig, end to end its about 3.5 ft or 42 inches long, 11.5 inches wide and 13.5 inches tall on the roof... the cat D8 T is also in 10th scale as i have decided long before to just create rc models in 10th scale. Im currently finishing the modeling, printing, test fitting ang installing the electronics and other accessories in time for some warm sunny day for the paint job to commence. I just got delivery of the tires so im putting it on and then take a photo and have it posted.
Old 03-20-2024, 10:09 PM
the tires have arrived... i think they are the right size at 130mm diameter and 60mm wide...
Old 03-21-2024, 06:21 PM
Oooooo... those look right at home. Any foam inserts in those tires?
Old 03-22-2024, 02:45 AM
they do come with inserts, these are 2.2 tires, luckily, i designed the rims to be 60mm diameter which is what 2.2 tires come with, and with a bit of stretching when you put it in... i might add another 10mm thick of foam to make it more solid and beefy...and also, to push the tire beads towards the rim lip, im pretty sure it will get a lot heavier when the electronics and battery are installed...and i dont want it to look like a flat tire when sitting still.
Old 04-15-2024, 08:46 PM
Update on the build... i have a driver, yay... the tires also i think is a good fit and quite realistic...
Old 04-16-2024, 04:40 PM
Were you able to set it up to steer with front wheel tilt for left and right
Currently Active Users Viewing This Thread: 18 (0 members and 18 guests)
