Old 08-17-2025, 05:28 PM
Blender's Avatar
Blender Blender is offline
Default 1:14 BMG C308 Excavator improvements
Been eyeing the modest priced, poor performing excavators for years. Using just the shell has been my plan as an economical way to build an excavator without making every single part myself.
Last year the C308 was released. Ordered it blind with only two small pictures and vague dimensions. Upon arrival the machine looks great. Lots of detail, lots of metal and very close to actual 1:14. The bad is the hydraulic system (as expected) gets blazing hot even digging air and pulls over 9A. Run time would be under 20 minutes. Valve block is not too bad. Respectable fine control, modular type for extension. Hydro lines are all 2mm OD but significantly smaller ID than SMC line. Chokes out the bucket and stick cylinders. Machine is very easy to take apart. Blade is electric and Aux hydraulics are fake with solid rod hard lines. Only 3 spool valve.
As factory built.
Short version of the heat is the stock pump spins way too fast. Included motor doesn't have the torque to run slowly. Swapping the motor allows better starting torque, but the internal leakage inside the pump becomes noticeable. System holds at 100psi with very little flow. At pump speed >3k rpm then flow increases significantly, and pressure builds to actually open the relief valve. The combo of pressure and flow increasing together makes everything jerky especially with the tiny bore cylinders. 9A through the stock motor is a lot of power which built a lot of heat.
The fix: leimbach pump with my own outrunner and reservoir similar to my telehandler build. Valves are ScaleArt since I wanted to try them. Boom and stick cylinders were swapped to Magom 10mm to increase power and reduce speed. Lines were all replaced with good stuff in 4mm and 2mm OD flavor.
Pocketing out to make room.
new slew system. I liked the servo drive, but it's too big.
skip a bunch of steps, and the hydraulics are working good with around 3A peak current draw. Stays cool. Stock tank was a really nice billet aluminum piece. Walls were too thin to bore out for the Leimbach. Replaced with a SLA printed tank.
Old 08-17-2025, 05:43 PM
Blender's Avatar
Default Re: 1:14 BMG C308 Excavator improvements
getting rid of the yellow paint took weeks. Livery will be Sunbelt Rentals to continue my theme. Boom bracket was rebuilt to better attach to superstructure. Original would rock under load.
sat in pieces for a couple weeks. Maybe I remember where everything goes.
laying down some color. Boom needs additional coats which is why it looks too yellow. Weird thing is the housing for the slew bearing is actually plastic. If it's an issue I will make a beefy replacement.
adding a Lesu 270 deg hydraulic swivel. My main use for this machine is to place 1:14 jersey barriers and this is a must-have. Simple brackets will dangle this from the quick coupler. The Kenco barrier gripper will be permanently installed. This machine won't ever dig.
Old 08-17-2025, 07:17 PM
Interesting, nice upgrades. Great improvement in pump performance. Were the boom parts cast also or assembled from pieces?
Old 08-17-2025, 07:38 PM
Blender's Avatar
Boom and stick are machined aluminum as two pieces each. Left and right are a press fit together with no external fasteners. Mostly hollow.
Old 08-24-2025, 08:45 PM
Blender's Avatar
Rebuilt all the hard lines with thinner wall brass for better flow. Surprisingly the soldering iron did better work than the torch. Ran out of fittings to do lines on the stick.
Two axis swing above the swivel. Top half of the Kenco is redesigned to interface. Can already tell the soft lines are going to influence the hang orientation.
New guy already ruined the paint on the counterweight. I'll let it ride until the weather is nicer to repaint.
Old 08-25-2025, 07:09 PM
Those new lines are going to look great. Gotta watch those new guys like a hawk.
Old 08-30-2025, 03:05 PM
Looking good Blender.
Old 08-31-2025, 06:47 PM
Blender's Avatar
Thanks for the kind words.
Plumbed everything. New hardlines worked great. No leaks and I can tell the cylinders are a little faster.
Been dreading the electronics on this machine and the telehandler. Both are a very tight fit. Ended up unwrapping the pump ESC to replace the wires with reasonable sizes. Bummer they don't make low-current escs with the same telemetry features.
Built the top half of the barrier lift.
Made a slightly smaller reservoir to prevent to motor from rubbing against the pack.
theorizing placement. Machine has 5 ESC: Pump, two track motors, slew motor and electromagnet for barrier lift.
Looking kind of possible. Wired it all up and the two double-Channel ESCs are not acting right. Gotta dive back in, or switch over to the tried and true fingertech "tiny"
animated Gif of swivel. Speed is about right.
Old 09-01-2025, 09:36 PM
Animated GIF? How-U-Do-Dat?
Old 09-01-2025, 09:51 PM
Blender's Avatar
Record a video on my phone. Email/transfer to PC
Upload video clip to https://www.freeconvert.com/convert/video-to-gif and fiddle with settings until it looks ok and not a huge file.
Host on imgbb as if it's a still picture.
Old 09-01-2025, 09:56 PM
Blender's Avatar
Also all my Sunday work was for nothing. The dual ESCs regularly go into calibrate mode and lose settings. Blink code doesn't match the instructions although I was able to reset one correctly. Not worth the headache.
Old 09-03-2025, 12:55 AM
What's your definition of "not a huge file"?
Old 09-03-2025, 10:38 PM
Blender's Avatar
The one here is 12MB. Pretty big, but OK. Ideally under 4MB and I'd consider 15MB an upper limit. Also depends on the image host you're using.
Old 09-21-2025, 03:55 PM
Blender's Avatar
Redid the electrical with tiny ESC's for everything brushed. Under cabin is kind of tidy, everywhere else is a mess. Need to move the receiver to next to the valvle block. Some wires rub the pump motor. Printed a sleeve to keep the battery off the pump motor. Slew motor was replaced with a tried and true, but a little glitch remains in the slew. Might be the pump ESC since I unwrapped it and swapped all the wires. Maybe a sloppy soldering job? Or the magnet's ESC doesn't like the inductive load. Tried the usual twist wires, add capacitors. It's subtle now. Pump revs slight when slewing left.
Built the remaining hard lines. The 2mm copper solder fittings were really nice so I ordered 50 more. Now the stick has brass tube for the swivel lines. Electrical wire run through the others for the electromagnet.
Test runs showed the boom was kind of weak, so I increased the bore diameter a couple mm. Much better and smoother with less radio tweaking, but now the stick cylinder is a little jumpy in comparison. May upsize both to be able to lower the system pressure and get the system smoother. May have parts on hand already.
Ran for quite a while straight through with no issues. At least 90minutes, probably closer to 2 hours. 10.5 V remaining on 3S LiIon. Nice runtime. Pump was warm to the touch with ~500 rpm idle and never exceeds 3k rpm.
Old 09-21-2025, 07:18 PM
Some great progress there Blender, it's looking real good. I like the size of the little ESCs you are using. Can you tell me where they are from as the photo is too blurry when I zoom in to read them. Do you have room to wrap the leads from the magnets esc around a ferrite ring? I've solved similar glitching with them. Really good run time you are getting also.
Old 09-21-2025, 11:23 PM
Blender's Avatar
They are Fingertech TinyESC from Canada. Super simple forward and reverse. No setup needed and very reliable. I get them from Palm Beach bots to avoid international shipping. Usually are in stock.
Ferrite ring is a good idea! If it works, I'll make room. Since everything went 2.4ghz I've never had a radio glitch until now. Super odd since I've run the same esc/motors/electro magnet on the Hitachi excavator before to test the concept.
Old 09-22-2025, 07:21 PM
Yea the change to 2.4 really helped clear up a bunch of issues but I still like to practice some of the old basics. I still put capacitors on all my drive motors. I've put motors on an oscilloscope and seen over 40 volts of ac when powered up by 12 volts dc. Thats noise that can still cause havoc. Two capacitors, one on each leg, will eliminate almost all of it. Some boards are more susceptible than others of course. I really like the sabertooth dual ESCs cause you can set up the mixing if you need it right on the esc and don't have to program anything in the transmitter but I've found they are really susceptible to noise. Thanks for info the the small esc you are using.
Old 09-28-2025, 11:17 PM
Blender's Avatar
Tried out a ferrite on the offending channel and the resulting channel. Did not improve. Swapped the motor caps for wherever else I had on hand. Might be a little better, but it's hard to tell. I do have the motor curve set as a hair trigger which isn't helping. Gonna leave it as is.
Pushed some electronics around under the body. Still a mess. Test fit in the case for an upcoming truck show. Trio of green will be represented, but c308 has to ride on the roof.
Old 09-29-2025, 07:23 PM
Good looking group of equipment. If you get some photos of them in action at your meet post some of them here.
Old 10-13-2025, 10:46 PM
Blender's Avatar
Show was fun but I only took one picture. Layout was very full. Many of us left some trucks out.
Currently Active Users Viewing This Thread: 20 (0 members and 20 guests)
