Old 08-21-2010, 12:55 PM
Juganought Juganought is offline
Juganought is on a distinguished road
Default Too fast!!
I now have the unit running, just a bit of soldering to do I am not too happy with the speed, too fast. Novak 55 turn, 10 tooth pinion, and locked in first gear cant keep up with it, Apart from a GRU, any idea's?
Dont mess with ma trucks
Old 08-21-2010, 02:11 PM
Thorsteenster Thorsteenster is offline
Thorsteenster is on a distinguished road
Default Re: Too fast!!
Less volts, more winds, lower gearing, or just don't move the stick to full!
Old 08-21-2010, 03:04 PM
try a 8 tooth pinion if that is to fast go to a 6 tooth
if still to fast in first gear might have to try a 3 to 1 or 4to 1 gear reduction unit between the motor and trans
Old 08-22-2010, 02:44 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Yeah lower pinion, then use the radio and adjust the EPA to suit. That is how I did mine before I had GRU.
Old 08-22-2010, 11:01 AM
Claus's Avatar
Claus Claus is offline
In my truck I have a Tekin FXR, 45T and a PMD 4:1 gear reduction after the transmission. The truck has great control, I run my truck in the house so it's top speed is plenty fast for me, fast enough to chase the cats around. This set up was kind of expensive but worth it to me.
Old 08-22-2010, 12:42 PM
Tamiya Cowboy's Avatar
You can do the same thing for 1/16 the money by using a 6 tooth pinon and a 55 turn motor.
Paul W. "Tamiya Cowboy"
Old 08-22-2010, 12:49 PM
Claus's Avatar
OK Paul, but I did not realize you were such a conservative when it came to RC trucks and money. LOL!!!
Old 08-22-2010, 06:47 PM
LOL I like to find cheaper way that give the same end result.
Old 08-22-2010, 08:24 PM
I'll try six tooth in my other truck. I'll let you guys know how I get on.
Thanx for the input
Juga
Old 08-23-2010, 10:50 AM
IDontKnow's Avatar
IDontKnow IDontKnow is offline
IDontKnow is on a distinguished road
Another way is to use the truck puller style motors.
I think its PMD that make them, only run to 6000 odd rpm but have a good amount of power. With standard Tamiya pinion (forgot how many teeth) it goes at a fast walking pace, if that makes sense?
Old 08-23-2010, 05:23 PM
Bob From Downunder Bob From Downunder is offline
Bob From Downunder is on a distinguished road
Since I'm into logging I wanted grunt, so I followed Pauls suggestion, I bought the Truck Puller motor out of Sydney and a 6 tooth pinion from the States. The truck is not finished yet so I don't know the results, just following advice of the experts....
Bob
Old 08-24-2010, 11:03 AM
Romelio Romelio is offline
Romelio is on a distinguished road
I was thinking of buying the pmd 4:1 for my knight hauler. I realize there will need to be a little fabricating but exactly how much? Will i need to buy any other parts to make it work? Thanks for the info.
Brian
Old 08-24-2010, 11:22 AM
diesel950 diesel950 is offline
diesel950 is on a distinguished road
in my king i have a 2.5-1 reduction with a 17 tooth pinion.
nice and slow in 1st,
bit faster than walking pace in 2nd
and highway speed in 3rd
but also has heaps of grunt.
like this much.
http://www.youtube.com/watch?v=lOsc3532JQ8
Old 08-24-2010, 11:24 AM
the reduction unit i used is also cheap.
but it has metal gears and bearings
so can take a lot of abuse.
cost $30aus.
Old 08-24-2010, 12:24 PM
Do you have a link?
Old 08-24-2010, 12:50 PM
Okay, I'm kinda not understanding this. If you guys are primarily gearing down to drop speed and not for torque, why not just adjust EPA or adjust stick movement to desired speed as it is proportional. Not trying to be smart *** or anything.
I think the extra speed would be nice in case you ever needed it. When I get my Volvo together I'll be putting my Novak Goat system in it, plenty of low end but good on top end too. Never know when you'll need some wheel speed for mud, cleaning tires etc etc.
Old 08-24-2010, 01:03 PM
You are right, Thorsteenster. I have decided to leave it as it is, and try and regulate the speed from the stick
Old 08-24-2010, 08:35 PM
If you adjust the EPA then when the truck is under a load such as pulling a heavy trailer or going up hill you wont be able to send enough power to the motor to maintain speed.
This is simple guys, for those of you who drive a vehical you don't drive it foot to the floor but you do give it more throtle to go up a hill so the throtle stick on your radio works just like the pedal in your car. If all else fails put in a gear reduction and put the hammer down
Truckpuller motor=high turn motor it is just a fancy name
Higher turn=lower rpm=more power
Lower turn=higher rpm=less power
http://www.rccartips.com/rc-electric...ning-guide.htm
Old 08-24-2010, 08:42 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
I know the price seems un-real but the PMD 4:1 is nearly unbreakable.
I have one truck with the 4:1 after the trans (stock pinion and stock motor) and 1 truck with a 3:1 and a puller motor before the trans.
The truck with the 4:1 can sit on a bridge and just hold itself without much throttle at all - shifting is nice and smooth ad there is no lurching of the truck (free rolling back and forth while sitting still)
With the 3:1 at the motor before the trans the truck will have that lurching aspect and it doesn't want to shift under load - you have to kinda back out of it just a little then she'l shift - kinda realistic but different.
The 3:1 cost me around 50 bucks from Willy and the puller motor was 35, while the 4:1 ran me 150
just some thoughts for those comparing .....
