Old 03-22-2011, 03:49 PM
sneaky-pete's Avatar
sneaky-pete sneaky-pete is offline
Master A-Modeler
sneaky-pete is on a distinguished road
Default Re: Mack M75SX
Nice work as always Steve.....keep the pics comming!
Troy
Old 03-22-2011, 04:23 PM
steamer's Avatar
steamer steamer is offline
Steve. Looking forward to pictures of that setup.
Rob
Old 03-22-2011, 04:48 PM
This truck is really looking really good. I understand you are running twin motors with different-from-stock pinions and driven gear going into the transmission? Would appreciate some detail on what gears you are running and did you have to build the two-motor bracket.
Thanks!
Old 03-22-2011, 05:05 PM
ihbuilder's Avatar
Ken It's an E-max tranny they come with 2 motor set up . The best guy to tell you about what I have would be Travis . I'm kinda trusting his jugement on the motor trans setup . If it works and has what I need for the pan , I'll be putting these in them too . I like the 2 speed idea .
thanks Troy
Rob the set up will take longer to true it up then to cut . If I get the CNC mill working , it'll be easier on that then the lathe , I'm thinking . If not then in the 4 jaw .
Steve
Old 03-22-2011, 11:11 PM
Heavy Metal Heavy Metal is offline
Heavy Metal is on a distinguished road
Just awesome work on this Steve. Looking great!!
What specific flux are you using on the alum?...was thinking about giving this a try...but not a welder. How hot we talking...do I need real tanks and torch or something that could be done lower heat like w/ little coleman propane torch?
Old 03-22-2011, 11:28 PM
ihbuilder's Avatar
thanks Joe B. , On the thin sheet a little propane will work but .125 and up gota use some heat . I got alumna flux at the hardware store made by forney and thought I give it a shot . you just got to watch the heat on the sheet , you'll warp it just like steal . It's hard for me to explain how , since I do it by feel . I only messed with it on some scrap , so we'll see how I do on the truck
Steve
Old 03-23-2011, 12:53 AM
mazdaparts mazdaparts is offline
mazdaparts will become famous soon enoughmazdaparts will become famous soon enough
The Emaxx tranny is a beautiful thing. I use them for most of my trucks. Are you gonna keep the 2 speed or make it a single speed? There used to be a conversion kit that almost cut it in half and basically locked it in 1 gear. I think you can still get an aluminum tranny case for it as well. Make sure you don't over tighten the tranny mounting screws, they strip out easily.
Old 03-23-2011, 03:44 AM
russisloud's Avatar
russisloud russisloud is offline
The Man The Myth The Ledgen RUSS OF DA LOUD!
russisloud is on a distinguished road
really starting to look like a dump truck now. its coming together great
Old 03-26-2011, 11:17 PM
ihbuilder's Avatar
thanks guys
mazda , I'm staying with the 2 speed
I did a little bit today got the 2nd axle made up and started on the pinion shaft openings .
and when you get a couple of big puppies together you might end up with a lil puppy
thanks for looking
IHSteve
Old 03-27-2011, 01:19 AM
Bigrigger's Avatar
Bigrigger Bigrigger is offline
Bigrigger is on a distinguished road
Cool! More Steve, more!!!!
Old 03-27-2011, 10:11 AM
kerst's Avatar
kerst kerst is offline
What kind of lathe do you use?
Kerst
Old 03-27-2011, 10:14 AM
ihbuilder's Avatar
Kerst , A Hendey , older then my grandfather early 1900's WW1
thanks trucker
Old 03-27-2011, 11:52 AM
td9clyde td9clyde is offline
Dozer Builder
nice work i am tryin to watch and learn lol Izzy taught me alot when he was at my old place
Old 03-27-2011, 12:12 PM
SmallHaul's Avatar
Good progress Steve. That is cool that you are making the axles!
Scott
"No load is too Small"
Old 03-27-2011, 01:11 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Steve, Do you ever sleep?? Seems like you are always making something besides all of the wheels you make. Old big machines are not all that bad. Most are built heavier than the new stuff which means you can do more before they break!! Keep up all of the good work!
LYNN
Old 03-27-2011, 02:01 PM
ihbuilder's Avatar
Scott , Clyde , lynn , thanks
Lynn , I put most of that lil puppy together sunday night after east mini truck meet .I basically used the merc running gear I had . I do not have much to do with it yet just make the body dump . As for the lathe , how many lil lathes take .25" off of 6061 t6 in a path ? my dad got a lil 7x10 clarke and said thats all he needed and didn't have a dino taking up space in the shop now he has me doing his stuff
I got more done will post tonight
Old 03-27-2011, 04:46 PM
kerst's Avatar
thanks trucker
The old machines are nice. i have a South Bend, which is "only" 70 years old. I love that lathe!
Kerst
Old 03-27-2011, 07:52 PM
ihbuilder's Avatar
yes they are
well this is as far as I go today the lathe control needs to take a nap
input output bearing plates ready to shim and bolt
thanks for looking
Old 03-27-2011, 08:05 PM
Dozer Builder
nice work slick job
Old 03-27-2011, 08:07 PM
Dreamweaver's Avatar
Weaver Of Dreams
Steve I have no clue what it is I am looking at, but the mill work is awesome any how.
Great Job
P.S. I see a set of fenders in the back ground, I know someone that makes the proper mounts for them...
Mike "DREAMWEAVER" Johnson
