Old 01-04-2011, 12:01 AM
Stuff's Avatar
Stuff Stuff is offline
Default Re: Liebherr LTM1800 scale 1/24
Wow! very impressive!!!
my YouTube is -
Subscribe!!
My Facebook -
Old 01-04-2011, 01:53 PM
Finster's Avatar
Finster Finster is offline
Great work! Very impressive build. What kind of glue do you use for the Al and brass? Do you need to do any prep work to the material before you glue it?
Brian
Old 01-19-2011, 10:05 PM
scalelover's Avatar
This is definetly one of the top builds going on, the time it would take even working daily for longer periods is asthonishing. So keep up the great work and I will stay tuned for the additional ...... years to finish it....
--Dan
Old 01-20-2011, 03:17 PM
D8R D8R is offline
Nice model, impressive. Hmm, 10 years, sounds familiar.
Dan
Old 03-15-2011, 10:20 AM
kerst's Avatar
kerst kerst is offline
A little update. I haven't had too much time lately between vacation, work and a huge ice storm.
I mainly worked on the drive train of the carrier. I bought a 540 motor with a reduction case attached (No, I did not make it myself, i am getting lazy), which fits perfectly.
then i did a test run and it worked great with the 2 speed auxiliary gearbox, but it lacked a low low speed, it just went too fast for moving it fully rigged.
So I decided to add a gear box which I bolted to the existing one, giving the option of an extra 1 in 4 reduction and a total of 4 speeds. That should do it! It is almost ready, most of the parts are there.
Kerst
Old 03-19-2011, 06:40 PM
kerst's Avatar
Gearbox is ready. It provides me with the Low-Low I need for moving the thing fully rigged and also with a few faster speeds. There is a factor 10 difference between the lowest and the highest gear.
Kerst
Old 03-19-2011, 08:15 PM
I LOVE GEARS! That is quite some assembly you have there!
Old 03-20-2011, 02:30 PM
kerst's Avatar
I made a short video of the first test drive. It is going in Low-Low with the motor running at full rpm's
http://www.youtube.com/watch?v=Zw_bQFV9amw
Kerst
Old 03-20-2011, 04:19 PM
Wow that is really cool to watch. I don't think I ever saw a 1:1 version turning that tight. That really works nice.
Old 03-20-2011, 08:31 PM
pugs pugs is offline
Very cool vid.
Jeff
Old 03-20-2011, 10:13 PM
kerst's Avatar
Originally Posted by SANDCRAFT TRANSPORT View Post
Videos like that are what make the build all worth while, WELL DONE!!!
I was pleasantly suppressed, I couldn’t see any play in the steering linkages as the wheels turned, I know how hard that is to achieve,
Tim
Thanks for the comment, but there is some play for sure and the 2 rear axles are a bit out of line. They steer a bit too much to one side, but I will adjust that later.
Now I have to fix the motor in place, it was sitting loose in the carrier!
I am not very good with RC, but it would be nice to have it remote controlled, then I could drive it at full speed. In the highest gear it would go the 1/1 equivalent of about 12Mph. I am thinking of making a module that would fit in the upper in the space of the winches. These can be taken out and then there is quite a bit of space..
Kerst
Old 03-28-2011, 09:02 PM
kerst's Avatar
After I finished the gearbox I put it all together.
Although there are still a million details to be done it is time to work on the boom now. Exciting!
kerst
Old 04-28-2011, 04:21 AM
Exiting, I'll say!!!! It's a rush to see a well designed and engineered piece of machinery work for the first time, isn't it? Great work so far. Just unbeleivable. Dan
Old 04-28-2011, 03:50 PM
kerst's Avatar
While waiting for the AL sheets to arrive I made the 235-ton hook block. I had very little (none!) information to help me and I had to somehow get some measurements from pictures. And now it’s finished I think it is not quite right. I might change the whole thing again.
I also made a first mock-up of the boom, just to try out if it works. I am using 0.032” Al sheet. I bend the lower part and the upper part separately and then glued the two together. It seems to work and it is quite strong.
Kerst
Old 04-28-2011, 06:35 PM
texken's Avatar
texken texken is offline
texken is on a distinguished road
Looking Good.
Did you say what Glue you used to glue AL.
TEXKEN
Old 04-28-2011, 09:07 PM
kerst's Avatar
Originally Posted by texken View Post
Looking Good.
TEXKEN
just look at the picture in post #54, the bottles are standing in the back ground. It is really good stuff, very strong.
kerst
Old 04-28-2011, 09:36 PM
kerst's Avatar
kerst
this is the eBay store: http://shop.ebay.com/polymerproducts...from=&_ipg=100
Kerst
Old 04-29-2011, 05:07 AM
Even if you're not sure about that 235 ton block, the craftsmanship on it is just beautiful.
Old 04-30-2011, 03:13 AM
TruckCentral TruckCentral is offline
TruckCentral is on a distinguished road
I would have to agree.. To the un"craned" eye you wouldnt even know. Very impressive so far.
Old 05-01-2011, 09:11 PM
kerst's Avatar
That's better:
I made the block about 1/4" shorter and now the proportions are better. I am happy now!
kerst
