Old 07-16-2011, 07:26 AM
Papy Papy is offline
Papy is on a distinguished road
Default Mack LRVSW
Sorry, just did not notice the server change, so have to re-post here
I started this project long ago to match my 88-B shovel.
The LRVSW is a direct ancestor to the famous M series off-highway trucks (see IHBUILDER M75-SX)
Comparing a Tamiya standard axle to the modified one I will use gives you an idea of the size of this baby (they are supposed to be same scale !)
The LRVSW was basically designed to be a dumptruck, but some of them have been used as logging trucks. Eventually, a couple were later transformed to be used as prime movers for heavy haulage work....
The model will be around 10kg empty (22 lbs) and will have a GVW of 21 kg (46 lbs).
I will have to fill the tires with some serious foam, as the original material is intended for lighter models and is a bit too soft.
Not sure I will keep the Tamiya gear box, but in that case, I will certainly add a 3 or 4:1 reduction gear.
Old 07-16-2011, 07:54 AM
kerst's Avatar
kerst kerst is offline
Default Re: Mack LRVSW
Wow! Looks great!
This Mack LRVSW is a great truck.
Kerst
Old 07-16-2011, 08:55 AM
doodlebug's Avatar
WOW! please keep us updated.
Later, Neil#2 aka doodlebug.
P.S. just saw this on on Big Lorry Blog, http://www.roadtransport.com/blogs/b...ltimate-m.html
Old 07-16-2011, 09:07 AM
Aussie's Avatar
Aussie Aussie is offline
Aussie is on a distinguished road
****, that looks nice, great work, love it
May I ask how you "widened" the Axle?? Looks fantastic!!
Paul
Drive it like you stole it!!
AKA Willsbrook
Old 07-16-2011, 09:47 AM
Now I see this truck on the CURRENT web page. I was puzzled by why my posts weren't showing up from one computer to another!
Glad to see another vintage off road dump being built. Like I said before that didn't show up here; "That will look nice with a certain 88B's 4cy dipper loading her up" Or, a 10cy dragline but you 'll have to bring it to the USA for that to happen.
Steve, You better get your Mack together.
Old 07-16-2011, 08:11 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Very Nice Great build
Look forward to more photo's and the building progress..
greg
Old 07-16-2011, 11:07 PM
ihbuilder's Avatar
I guess my ears were ringing earlier I just ordered the remaining tires for the MX 75 .it may be the only piece of equip I get going for york
looks great Papy
Old 07-17-2011, 05:03 AM
Thank you for te link, Neil#2
Paul
This is how it's done :
Old 07-18-2011, 12:36 PM
rc_farmer's Avatar
Master Builder
Good start to a fantastic looking truck!
Forgive me if this sounds dumb......but how did you spline the ends to fit into the diff or did you slide this over the existing rod? (i am no machinest)
Giving up is not an option!!!
Rob
Old 07-18-2011, 01:27 PM
As a "no-machinist", I must say your work is rather impressive
I just kept the original shafts, drilled my additional length 0.2 mm less than the external diameter of the splines and "forced" them gently over the existing splines. I used the lathe as a press to maintain everything centered and avoid any bending. Not sure my explanation is clear, so I can take a picture if needed.....
Old 07-18-2011, 06:02 PM
Did you use any Lock-Tite as an extra security to your press fit hub?
You get that trk done & I'll have a job for it.
Old 07-19-2011, 02:17 AM
No Lock-Tite.....
For the job, you'll probably have to wait a couple of years.....or a couple of decades
Old 07-19-2011, 03:10 PM
mack kid mack kid is offline
mack kid is on a distinguished road
Great build going. cant wait for more updates. like those front rims did you build those?
Old 07-19-2011, 03:47 PM
Yes, the rims are custom made. Two full buckets of metal chips
Old 07-19-2011, 03:57 PM
Old 07-19-2011, 04:25 PM
ihbuilder's Avatar
nice job on the wheels did you make 2 extra fronts they look right on . I hope mine come out as nice great job on the front axle too , I may remake mine like it is supposed to be ( tubular ) I finally got the rest of my tires coming
Old 07-19-2011, 11:47 PM
kerst's Avatar
Those wheels look very nice! Beautiful work!
Kerst
Old 07-20-2011, 01:36 AM
Exquisite machining skills Papy, continuing detail work like that & it could be decades, I suppose.
Old 07-20-2011, 02:25 AM
Originally Posted by ihbuilder View Post
nice job on the wheels did you make 2 extra fronts they look right on ....
I still have the original drawings and even G-codes.........
Old 07-20-2011, 10:02 AM
WOW. those front rims add a perfect look. great looking truck. keep those pics coming.
