Old 12-01-2011, 08:54 AM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Default Audio jack for slip ring?
Hi all ,was watching this vid,around the 30-35 sec mark,that looks to be a audio jack ,just wandering it that was what it was,and if that would work for a slew ring for a bruder conversion mabey.
http://www.youtube.com/watch?v=VNd_DcxEh9c
Old 12-01-2011, 10:37 AM
Default Re: Audio jack for slip ring?
That is a ingenious way of doing that and very easy to dismantle. That would work perfectly on the lighter models. You should still use a bearing in conjunction with the plug to take some of the load. I wonder how many circuits can be had on a audio jack. Definitely cheaper than a slip ring.
Old 12-01-2011, 10:54 AM
That's a great idea... I was just about to attempt some sort of connection today or tomorrow because my drive motors arrived yesterday. I would think that if you used a plug from a set of stereo headphones you get 2+ and 2- connections. How much amperage would they handle in a 40-50lbs model though I wonder?
Reg
Old 12-01-2011, 12:31 PM
JensR JensR is offline
I use one in the circle drive of my grader.
Mono has two poles
Stereo has three poles (common ground, left, right)
There are some four-pole ones available, but I only found them for the smaller sizes, not the big 6.5mm ones.
Not sure about current - my four-pole one seems to work fine with the 1A to 2A I am sending over it.
They are not meant for many rotations and a bit susceptible to ingress of dirt, but they are a nifty way of doing that - for small models and large plugs, you might even get away without an external bearing to take the load.
Old 12-01-2011, 01:19 PM
pumptech's Avatar
Thanks guys, hey jensr thanks for the info,didn't know that about the stereo/mono plug. May have to swing by radio shack and take a look ,do some experimenting with it,my bruder excavator may be a candidate for it,lol.
Old 12-02-2011, 12:00 AM
He's definately sticking the "Keep it simple stupid'' (KISS) analogy!
Thank's for sharing!, Neil.
