Old 12-19-2011, 12:05 AM
rockNmayhem's Avatar
Default Re: Over The Road Hauler "OverHaul"
Well ladies and gents. It's been a while since I've had an update on this rig but its been slowly going. I got a bunch of parts in since last time and almost have a roller going now. I have yet to finish up the rear suspension and get some fenders for the front then it will be the finishing touches soon hopefully.
So far I got in a set of amazing Freddy rails and several awesome goodies from Russ as well. I running air ride in the rear, custom fuel tanks and mounts along with his new battery box steps and a contoured front bumper. I've also gotten one air cleaner started right now and should be getting the other done this week possibly.
Anyways enough of the small talk, I'll let the pics do the rest of the talking.
This truck is sitting at factory mounting height with the low pro tires on it and it is definitely a belly rubber. I may have to end up going back with the stock size tires or modding the front bumper for some clearance if this ever gets to see the outdoors.
Lemme know what you guys think of the rig so far.
Tyler
~Tyler~
RockSolidCustoms
Old 12-19-2011, 12:28 AM
gauthib12 gauthib12 is offline
gauthib12 is on a distinguished road
Nice work! I am curious, where did you get the snazzy part for the rear end of the frame rail? I like the way it slopes..more scale like.. anxious to see this rollin!
Old 12-19-2011, 12:33 AM
russisloud's Avatar
russisloud russisloud is offline
The Man The Myth The Ledgen RUSS OF DA LOUD!
russisloud is on a distinguished road
tyler, if you need to mod the front bumper let me know
Old 12-19-2011, 12:58 AM
That rear plastic cross brace and the drop pieces for the end frames are from my aeromax kit I had.
Russ I may just be in touch, I'll shoot ya a pm.
Tyler
~Tyler~
RockSolidCustoms
Old 12-19-2011, 12:59 AM
Hmmm, the front tires definitely look a little on the small side, and I think you could go with a slightly shorter bumper. It looks a little on the tall side. I like when they are low, but that one is sitting on the ground instead of above it! How tall is it?
Old 12-19-2011, 01:07 AM
Hey Nathan the bumper is right at 2" tall and would be great on a factory sitting rig. It would be about 3/16" off the ground but with these low pros that ain't happening.
Also I noticed the pics are giving a misconception of how big the tires are but if I hadn't moved that axle forward in preparation for the new pete fenders that this truck will have they would sit in the wheel arch much better and not look so gaudy.
Tyler
~Tyler~
RockSolidCustoms
Old 12-19-2011, 02:12 AM
I noticed right away the wheels were centered in the fender, but that's a huge difference between low pros and stock sized tires. 3/16". Wow. I didn't think it was that much!
Old 12-19-2011, 11:13 AM
Snowman's Avatar
Snowman Snowman is offline
Snowman is on a distinguished road
Looks great so far and will look even better with the new front fenders. The egg-shaped king ones just don't cut it if you want the front axle moved forward. My truck is sitting on lo-pros and I got Russ to make me a bumper that was 45mm tall. That's less than 2 inches (1.77). Can't figure out what that is exactly as my brain can only cope with decimal! Keep up the good work, this will be one unique ride!
Nick
My Peterbilt build thread:
Old 12-19-2011, 10:19 PM
CustomClod CustomClod is offline
CustomClod is on a distinguished road
Looking great! Keep the pics coming
Scott
I run a single stack Mack with a dump body on the back!
