Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > S n P Customs
S n P Customs Custom builds, Custom parts, Custom metal polishing...
Old 03-08-2011, 12:28 AM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
Default Custom fenders
Custom plastic resin full fenders...$40..mounts needed..
Also Custom Double hump fenders.$55 a set..mounts needed..
And soon to come single hump fenders for your speadaxle trailers and triaxle tractors...
One Bus Stop Short Of The Short Bus...
Old 04-02-2011, 06:45 PM
scalelover's Avatar
Default Re: Custom fenders
I picked up a set of the double hump fenders and they are very well made. Also a great guy to deal with. Keep up the great work.
--Dan
Old 01-08-2012, 05:47 PM
I'm tryin Boss!
Hey all...Im messing around with a different style of double hump...this a is just a rough copy..but if any interest i clean up to make the master mold..i will be also doing these in a single for trailers too..
thanks for looking
Old 01-08-2012, 09:48 PM
WOW John, those are sweet. You've got me thinking of a future project
Old 01-08-2012, 11:36 PM
I'm tryin Boss!
Thank's big John...Have some more work to do to them...going to make the outside go straight down..just a nicer look..like this
Old 01-09-2012, 02:01 AM
MACK Daddy's Avatar
MACK Daddy MACK Daddy is offline
MACK Daddy is an unknown quantity at this point
I think those would look hot on my 362 Pete
Very Nice John
Alfy
Old 01-09-2012, 03:35 AM
I have to agree John, that's just look's sexy...nice curves.
Old 01-09-2012, 08:38 PM
I'm tryin Boss!
Ok..Now they go straight down..now time for the body work..
Old 01-10-2012, 02:44 AM
Dreamweaver's Avatar
Weaver Of Dreams
Send me a pair!!! I can make mounts for them to..
Mike "DREAMWEAVER" Johnson
Old 01-23-2012, 09:56 PM
Bigg Redd Bigg Redd is offline
Bigg Redd is on a distinguished road
Can these be made for a Wedico Pete!!!!!
Old 01-29-2012, 10:39 PM
I'm tryin Boss!
Ok here they are....there $55 shiping included....Must make your own mounts..everyone mounts them different to there own taste..unless someone wants to make mounting kits...hint...hint..hint.....anyone....
Old 01-29-2012, 11:25 PM
Tamiya Cowboy's Avatar
YEP 2 Please!!
Paul W. "Tamiya Cowboy"
Old 01-30-2012, 03:15 AM
Weaver Of Dreams
Ok
I can't really make a "kit" cause they can be mounted at different heights.. But I can make them to order...
Old 02-05-2012, 01:06 AM
1985 kenworth's Avatar
Question Re: Custom fenders
how would you make them to order by which tamiya or wedico tractor you have and which suspension you are using on the tractor
Old 02-05-2012, 01:11 AM
They would be made for a Tamiya truck with a standard suspension or a custom suspension as long as the ((wheel base) typo should be wheel spacing of the rear axles) stays the same. The fenders are made to fit a standard Tamiya truck.
Old 02-05-2012, 11:40 PM
ok i have a kinghauler and a globeliner the suspension is stock but the wheelbases on them are longer than the standard box stock trucks are you sure the wheelbase would be an issue i thought the axle spread would be the a problem ..i am talking about someone building the mounts to mount them on the trucks
Old 02-06-2012, 12:18 AM
BRICKNICK's Avatar
BRICKNICK BRICKNICK is offline
BRICKNICK is on a distinguished road
Hey John this things look awesome, really adds to the wifes rig. Gives it that extra attitude in the back half to match that new meaness the paint job graphics added. Nice work as usual buddy.
Old 02-06-2012, 02:57 AM
Weaver Of Dreams
I build them so that they fit the way you want them regardless of the make of truck or type of suspension. I get measurements from you, I let you determine how high you want them to sit from the wheels and the ground then build them to fit.
I guess I could make a "Stock" set. If you have a stock Tamiya suspension, stock ride height ect and you want the full length fender as they come from John then no measurements are needed. I could also build a set that has a little extra adjustment to them and someone with basic soldering skills can make them the height they want and just trim the excess.
Old 02-06-2012, 03:01 AM
Weaver Of Dreams
Wheel base would not be an issue unless you changed the drive wheel spacing, which you can't do if using a stock suspension. However if you were to use the air ride kit that Russ sells then you could change that spread. However if you were to change the drive spread then the fenders would not fit anyway.
Old 02-06-2012, 09:03 PM
I guess that was my bad when I said wheel base I should have said the rear axle spacing and if you changed that it would not mater what brackets you made the fenders would not fit and the fenders are what I was referring to not the brackets. Sorry for the confusion.
