Old 02-11-2012, 08:30 PM
Bsorenson79's Avatar
Default Somthing cool I just found on Ebay
http://www.ebay.com/itm/TAMIYA-KING-...item3a704c7f01
Has anyone ever seen this truck before?
Old 02-11-2012, 08:49 PM
Default Re: Somthing cool I just found on Ebay
It would definitely make a good place to start for a custom build but it is kind of rough in places.
Travis
Old 02-11-2012, 09:30 PM
Travis
'If you read the description some of it is made out of wood.
Old 02-11-2012, 09:41 PM
The guy said it wasn't perfect in the description and you can clearly see it in the pics. So I am not sure what you meant in your last post if it is about the use of wood in the model many builders here on the board use wood and you can't tell it.
All I meant is with a little work it could be a real show stopper.
Travis
Old 02-12-2012, 12:29 AM
Travis
Being newer to the actual building side of the hobby, It was a little different to me that there was wood used in the build. From following builds I always noticed everyone used styrene for their builds. A couple times I actually was wondering why the use of wood wasn't more popular.
Old 02-12-2012, 11:35 AM
Check out this grader build thread.
Link
Travis
Old 02-12-2012, 01:23 PM
whats the issue yea it's a different truck made of wood I've seen a lot of different materials used to build something . wood is 1 of the common materials . If you get to spend some time in the construction forum , you'll see some old cats built by Jerry from wood and , as travis mention , Robs grader . A lot of RC aircrafts are built from wood .
Old 02-12-2012, 01:28 PM
Link
Travis
Wow! Thank You! I never knew that grader was built using wood.
Old 02-13-2012, 09:02 PM
BRICKNICK's Avatar
I think that truck is sweet, would be a great start for a real custom stand out truck.
