#221
I'm still useng hydros I just went with the lift design on my IH4600 1:1 dump . no room for a screw drive with these rears . I also have 1 rear locked , so I might not need to redesign my walking beams Quote:
Now to get this loader running
#222
Truck looks really good steve-I like the way it bounces when loaded. Kinda like the real ones. Do you need me to make you some tires that will stay on the rims
![]() ? Nice job.
#223
Awesome, Awesome, Awesome!! You can see the torque, bout' does a wheelie. Great job Steve! What does it weigh as it stands now, how much do you thing the load weighed? I wanna try it, can I have a turn?
Ben
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 |
#224
Steve, you hit a home run with this bad-boy! It is large, but seems like plenty of power with the two motors, and acts like a real one - carries plenty of payload. It will look so much different when painted.
Want to see it first-hand sometime. Ken
Big iron is awesome! |
#225
Nice job steve that is a monster with tons of power to boot.. Can't wait to see it all finished in paint..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#226
That looks just awesome. Slower would be more scale probably but sometimes its nice to be a little fast to get around. You need some solid tires for sure with those impressive loads!
#227
I finish up a few things and loaded her up for a move to it's 1st job next sat. to see how she'll hold up . See if I can burn the ums pump motor up (not really want to ) ![]()
#228
Man, I love the Mack M series trucks. Some of the coolest Prime Movers I have ever seen are Mack M's. Jusy massive trucks.
#229
Looks cool getting hauled by your IH heavy hauler, killer combo!
Nick My Peterbilt build thread: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#230
What?! no video of it being hauled around?
#231
I have 1 but it's hard on the eyes to see and it's dark again
#232
Dang Steve, you really need to buy a better camera! I know it cuts into your funds for tooling, but how are we ever going to fully appreciate the craftsmanship?
Nathan |
#233
actually not , something else takes those funds and will for another 2 years ![]() ![]() I still got obligations to fullfill from when income was steady till '08' hit . It worked the best on sunday at cabin fever after I put in an external bec and started gluing the tires . I had to consentrate on feathering the throtle to keep the spinouts down . I meet a guy at the show who took the pic of the real 1 in the mack history book and knew of some of the smaller mseries in my area . He told me the M75's didn't like to steer just like the model . Someday , I'll be running out to NJ to see the real 1 in mack history book .
#234
Awesome truck and great combo!
![]() For the camera, you can put it onto a bean bag (which you can make yourself) or just something that is stable and a bit off the ground, like a few books or aluminium blocks , this prevents camera shake.If you then use the self timer, it will be even sharper. Also, for close shots, using the macro mode might be necessary to get sharp shots. |
#235
Here is a few history shots from where Stevie's M75 evolved.
Mack LVX ![]() ![]() ![]() Model 1938 FC Chain drive
#236
By the looks of the Mack cab I would say that Euclid copied them as close as they could. It's like they had the same mother but different fathers.Haha.
#237
![]() ![]() ![]() ![]() Thank's for sharing Steve! Cheer's, Neil. |
#238
thanks Steve , I'm trying to picture in my head where that pit is
I heard the name of the co. somewhere . if you get on 209 from port carbon Pottsville head to Tamoqua Its like your driving through a trench . sometimes you can see some small drags working on the banks . all you see is the boom maybe a glimer of red/orange in the trees I've did some home excavations in those hills . 18% grade roads is the norm I'm wandering who really made the frames for those trucks . My dad worked for a co in 60's/70's (before I came in this messed up world ) that dug some of the fondation work at mack for the machines to make the rear axles on those trucks .I'm going to have to make a short trip to the mack histiric center someday , you up to it Scott ?
#239
Maintenance day today
then the barge came in with a load of coal that needed unloading Altough it was just a little barge (250 ton ) I changed the motors to 65t lathe motors , what a difference still got some kick in her in 2nd but 1st is a nice speed for workin in a crowded area . I had some probs up loading to y tube so I up loaded to PB for now when uploading to y-tube finally worked the batts died in the cam ![]() coming out of the docks ![]() ![]() dumping in the stock yard ![]() starting to get a little wear in the body now ![]() ![]() I'll get the vids on y-tube later tonight ![]() I gotta learn how to edit vids now
#240
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| Thread Tools | |
| Display Modes | |
