Old 07-09-2011, 12:49 PM
Car5858's Avatar
Car5858 Car5858 is offline
Default Re: Oshkosh Het M1070, M1000
Your welcome, and thanks for looking.
Old 07-16-2011, 11:56 AM
Car5858's Avatar
Got a call from my Dad last night, He did get a couple more rims done. The problem he had while skip cutting the od, caused the spindle drive pinion to fail, about 3 teeth are missing.
I bought this lathe 12 years ago, an Atlas Craftsman 101-21200. Finding parts for the is tough.
Since the pinion is cast onto the spindle pully, I am going to try to repair the damaged teeth. Still trying to locate the part.
So the rims are on hold for now.
Old 07-18-2011, 01:06 AM
muskater muskater is offline
muskater is on a distinguished road
That's a bummer! good looking build hopefully the machine will be up and running soon
Old 07-18-2011, 02:18 AM
I understand Clausing bought Atlas and they still provide repair part's, try this site.
http://www.clausing-industrial.com/service-std.htm Hope this help's!
Later, Neil#2 aka doodlebug.
Old 07-18-2011, 03:37 AM
Car5858's Avatar
Thanks Neil, I have talked with them on the phone already. They are searching the warehouse for the part.
So far the repair is holding, we will see how it holds up under a load.
Thanks everyone.
Old 07-24-2011, 05:31 AM
Car5858's Avatar
Well no luck on repairing the teeth, or finding a new part. I was able to lock the cone pully to the spindal shaft. Just reduces the options of spindal speeds, we can deal with that. Now we are waiting for the heat wave to pass.
I did get some parts in, pinion bearing covers. I did not think that the abs plastic would hold up to well, and there was an alignment problem. So I redesigned the covers and had them made by the students in the class. One cover was rejected as incorrect.
After deburring and fitting to the covers I drilled the mounting holes. IT went togather pretty nice.
One step closer
Old 08-21-2011, 03:54 PM
Car5858's Avatar
Small update, still awaiting parts maybe they will be finished soon.
In the meantime I designed an 8-71 Detorit in 1/16th amd 1/14th scales.
I have all the parts drawn but still need to dimension them.
One question that I have not been able to answer is how the A/C compressor is mounted.
If any one has some input please feel free to advise me. I was going to post some pdf files but they are to large to post so here are some screen shots.
Old 08-21-2011, 07:09 PM
Smokin Joe's Avatar
Your ability to build aluminum parts with hand tools is second to none.
I'm inspired to attempt making parts I would not have in past. Your parts show what a artist you are.
I'm convinced now that those how call Picasso a artist have not seen your work! Joe
Old 08-21-2011, 07:53 PM
Car5858's Avatar
Thanks Joe
Old 03-11-2012, 12:24 PM
lmno01 lmno01 is offline
lmno01 is on a distinguished road
I have about 2 1/2 years with the Het and they do not come stock with AC in the models we have. The Super Het M1070A1 does but I doubt we will see those for years.
Old 03-12-2012, 06:28 PM
Car5858's Avatar
Yes that is true. My cousin was Co of transportation Btl. He was the one that got me interested in these trucks. Hopefully I will be able to some more work on this one when Classes let out for the summer.
Old 03-14-2012, 09:28 PM
george george is offline
george is on a distinguished road
Hello Car5858
Your build is Incredible please keep the build pictures coming.
Thanks Again for Your Posting
George
Old 03-14-2012, 10:24 PM
Car5858's Avatar
Thanks George, it will be a couple more months before I can get back to the build. At least the weather will be warm
Old 03-17-2012, 01:06 AM
Hello car5858
From your posted pictures of the frame rails are those cross members solid or tubular aluminum and how are they actually jointed to the side rails?
Also what material did you use for the air bags? Is it functional OR cosmetic?
Keep them pictures coming.
Thanks Again
George
Old 03-17-2012, 01:26 AM
Car5858's Avatar
The cross members are milled from solid stock. Then the 4 top bolts hold the cross members in place. At the same time bolting the axle mounts in place. The air bag mounts also bolt into the rear frame cross member. The material was 3/4" square aluminum stock. (6061)
Old 10-06-2012, 01:18 AM
JoseFL10-4's Avatar
JoseFL10-4 JoseFL10-4 is offline
JoseFL10-4 is on a distinguished road
Is a nice project, want see more pic soon
Old 10-06-2012, 04:09 AM
Car5858's Avatar
Yes I have been meaning to get some more pic's posted. Illness has pretty much wasted the summer. I will get back on the truck soon I hope.
Old 10-06-2012, 10:41 PM
Hope you feel better soon! Looking forward to more progress
Cheer's, Neil.
Old 10-23-2012, 05:51 PM
Car5858's Avatar
Thanks Neil.
Old 12-30-2012, 07:31 PM
Hi Car 5858
George from Cold Canada. Long time for us both on this site. I have had health issues also. I look forward to be able to go ahead with this project too but I have to go slow.
I hope you are feeling better because your work is inspiring and infectous!
I need more pictures, getting withdrawl feelings!!!
George
