Old 03-05-2012, 03:30 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default My Work Train
This is my home away from home for 5 days a week.
It's a '06 KW W900L
565 hp Cummins ISX
18spd Eaton
355 rears
Main Trailer
'97 Polar Pneumatic 3 bay
Pup Trailer
'93 Polar Pneumatic 1 bay
Tare Wt 43,200#
Gross Wt. 118,000#
Total Length: 104 feet
I haul Soda Ash and Trona from the Little America, WY area to Barrick Goldstrike Gold Mine 22 miles north of Carlin, NV. Or I haul Lime from Wendover, NV to the gold mine.
This will be my next project... Travis this is the reason for the KW grill.
Mike "DREAMWEAVER" Johnson
Old 03-12-2012, 09:21 PM
Diesel Demond's Avatar
Diesel Demond Diesel Demond is offline
Diesel Demond is on a distinguished road
Default Re: My Work Train
hay something is following you in the picture!! lol never seen a phnuematic that small before
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!!
Member of the Central Plains Mini Truckers,and a Minnesota road hammer.
Flat bedders do it with chains and straps,but now im yanking 53's
Old 03-12-2012, 10:46 PM
Weaver Of Dreams
That's why it's called a Pup
it's small but holds a bunch. I put 44,000# in the main and 30,000# in the pup
Old 03-13-2012, 06:36 PM
from the picture thats hard to beleive 14,000 diff
Old 03-19-2012, 12:19 AM
Wow, looking at the size difference between the trailers, I would have never guessed that. The big trailer surely can't be filled to capacity, with just 40K pounds? It looks 3 times larger then the pup.
Old 03-19-2012, 02:07 AM
Weaver Of Dreams
Oh no, no where near capacity in fact I would say about 3/8 to 1/2 full. The pup isn't even full with 30k.. with the majority of the stuff I load, if I filled the trailers completely I would have about 120k to 130k worth of load. DOT would give me a nice award if I did that.
Old 04-13-2012, 09:04 PM
Weaver Of Dreams
Well spent a day with a buffer recently and got it all polished up. Well everything but the steps. They are so trashed even gray rouge would not cut them.
Old 04-14-2012, 06:23 AM
Roadmasters's Avatar
Roadmasters Roadmasters is offline
Moderator
Roadmasters is on a distinguished road
Looking sharp!
"My son will have a chocolate milk" -J.P.
Next East Coast Minitruckers Meet:
Arioch
Old 04-14-2012, 07:44 AM
doodlebug's Avatar
Ever heard of shooting clover seed out of a sand blaster, to take the oxidation off of the aluminum? Vic up @ Vicar told me that, years ago.
Cheer's, Neil.
Old 04-14-2012, 10:43 PM
Weaver Of Dreams
Cheer's, Neil.
Nope that's a new one to me. If your talking about the trailer rims.. No need as soon as I get my pup back next week (that's not my pup in the picture) then the boss man is going to have all new outside rims put on it for me.
Oh and to explain why I don't have my pup.
Well on the morning of March 30th, I left the house went and hooked up my trailers, did my pre-trip (and I do a real one not just kick the tire and look at the lights). I left the place where I park the trailers while home made two left turns the second of which I have to go through a dip in the road. After I made the second left and was heading out of the sub division to the highway, I look in my right mirror and I can see BOTH of my tires on the front of my dolly.
I pull over go back and look and the right side of the A frame on the tongue of the dolly had broke in half. Under further investigation they found that the metal had been cut some time ago, probably with a saws-all, and then a piece of DOT reflective tape placed over it.
I'm just darn lucky that I was not running down the road either loaded or empty when it broke.
The part between the arrows was perfectly smooth and straight. This is where is had been cut.
Old 04-15-2012, 07:38 PM
doodlebug's Avatar
Wow, that put's the "PUCKER'' in thing's, glad nobody got hurt.
I lost my other tag trailer year's ago, crossed a deep cross gutter full of ice, trailer jack caught on the ice and the
lunette or eye snapped off, and dropped the loaded trailer. Six States had one on the shelf. scrapped that one later on.
The clover seed is hard enough to break up the oxidation, but not pit the aluminum.
Cheer's, Neil.
Old 02-28-2014, 04:58 AM
Weaver Of Dreams
Word to the wise.... DON'T lose your main fan belt on a cummins ISX while pulling 117,000 pounds up a 6% grade...
On the 10th I was heading out west in Nevada going to the gold mines when going up a grade my fan hub seized up and fried the belt which on a ISX is the only thing turning the water pump.
Well in no more than ten seconds my alternator light came on, then my engine shut down light came on, them my engine stopped immediately, like right now....
Got it in the shop and the results were less than thrilling...
Head cracked in four places... Replaced
Turbo cracked and 2 fins broke...Replaced
EGR cooler melted inside.. This is what stopped the engine, it filled the #6 cylinder with coolant and hydro locked the motor... Replaced
Fan hub... Replaced
4 pistons and liners scared and the #6 connecting rod bent... Replaced
Water pump seals melted...Replaced
So basically if your keeping track
Engine block, crank, and electronics... Original... EVERYTHING else replaced
$30,000.00 bill (Thank Goodness I don't own it)
Now for the cause. My fan clutch stopped working on the 6th so I went into our Wells, Nv terminal and had it fixed. The mechanic had a complete rebuild kit for the fan which included new bearings for the hub. There was also a nice note from the manufacturer on the fan clutch when you opened the box that said "ALWAYS replace hub bearings when rebuilding your fan". However the mechanic knew better, spun the hub by hand on the bench and decided that the bearings were just fine.... WRONG
Hopefully they will have it done tomorrow and I can pick it up Monday.
Mike
