#121
I don't think anyone wants to see this project done more then I do. I've been working on it for such a long time now, but I've gained some momentum back. I just have to keep it rolling. I'm doing a little every day, when I can, but more so on weekends. That's when I seem to have the most time to play with things. Funny you mention the rubber fender extensions, because it is on the list of things to do, but that list is quite long at the moment! Maybe what I need, to put the pressure on me, is a feline supervisor, like you have!
Nathan |
#122
Holy ..........those steps are out of this world!! Watching eagerly.
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#123
So, a small update. I've been finding the time before work each day to do a little more on the boxes. The last two days I've been working on the steps, which will bolt up to the tool boxes. The side members are all done! It was a tedious process to machine such small parts. I did run with the 0-80 screws, which seem about perfect for the task of holding things together. I'm glad I didn't go smaller. I think these are the smallest I would want to try and use for a build like this. They are so tiny! Drilling and tapping went without a hitch. I also milled the side members and gave them the proper angle on their face, to match the 1:1 boxes. These little buggers are really taking the time to make. I think I have 15 hours of work in them. Pictures of the last couple days of work. ![]() ![]() I think I'm on a machining high right now! Still more to do. I need to make the tool box doors themselves, and drill and tap a few more holes to bolt the steps to the boxes. Also, the top tread plate is still not bolted down either. This should be a simple job, after accomplishing today's work.
Nathan Last edited by Espeefan; 03-22-2012 at 09:34 AM. |
#124
Nice work and attention to detail.
#125
great job nate
"I think I'm on a machining high right now!" It doesn't take long does it
#126
Those steps look outstanding. Why not countersink the screws though?
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
#127
WOW! Very nice for sure.. Probie on the real ones some brands have alum rivets in the areas that he has the screws.. I like the look it is a nice touch..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#128
Turned out real nice Nathan, those screws look good!
#129
Thanks Scott. I appreciate that.
Thanks Kent. Almost finished with these things. Then it's onto the the next set of parts. Some nicer fuel tank saddles, if I am capable!
Nathan |
#130
Nathan those are the best steps i've seen great job the only thing missing are one slam locks
RIP FreddyGearDrive 2-12-59/12-19-11 Love my Kenworths To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#131
Thanks Tracy. I'm actually working on the doors with lock details. Have to see what I can up with. These aren't quite finished yet.
Nathan Last edited by Espeefan; 03-23-2012 at 09:52 PM. Reason: I can't run a keyboard. |
#132
Nathan, this build is the boom daddy. Those steps look great and are totally unique. I'm impatient to see the finished article.
Have you considered half counter sinking the screws? They wouldn't stick out so much and there would still be enough material for it all to be secure. You could even mill the protruding part of the screw off at a later date. Just a hare-brained idea.
Nick My Peterbilt build thread: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#133
Youre wasting no time breaking in that mill!! Love the custom parts, looking forward to seeing more.
How will they mount? ![]() that's too funny! Its actually Arioch, but I like Archie
"If you build it, they will come" East Coast Mini Truckers To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#134
WOW love the steps!!
#135
Anyway, the tool boxes will mount up pretty readily, from the rear. I think I'm just going to drill and tap some holes and bolt them to the frame rails. Easy and clean. The screws will be hidden! Argh! Arioch, I apologize! I'm not good with names! No harm intended! Thank you dabears. I think da steps are pretty cool too. ![]() Okay fellas, I've got just a small update here. This will be all for the weekend edition. I'm needing to order up some more end mills and a little more material, but I did get a start on designing and machining up a couple extra mystery parts for the Wedico. I won't say what they are yet. They are in a pretty raw state. For a hint, there are two parts per plate. ![]() ![]() The smart guys will probably figure it out! Any guesses?
Nathan |
#136
A flux capacitor?
#137
I bet I'm close!
#138
The steps look amazing! It's amazing how much work can go into one part. I have broken off small taps and drills and it is not fun. I understand about being fearful of breaking off a tap. Although somewhat larger than a small tap, I recently broke a 1/8 carbide end mill off and was able to "drill" it out with an expensive OmegaDrill tap drill. It worked great. Unlike the last time I drilled to drill out a broken tap where I ended up trying various other drills and endmills that only resulted in making them dull.
#139
![]() ![]() http://omegadrill.com/Cheer's, Neil. |
#140
I'm a big fan of Back To The Future, so I appreciate the humor, but I don't think this truck will hit 88mph.
![]() If you are thinking what I am thinking, quite! Quote:
Nathan |
| Currently Active Users Viewing This Thread: 570 (0 members and 570 guests) | |
| Thread Tools | |
| Display Modes | |
