Old 04-30-2012, 08:54 AM
Default Re: Let The Build Begin!
Dang, to bad I wasn't as good as you were in the 12th grade! You're gonna go far, kid!
Old 04-30-2012, 11:00 AM
Madda Madda is offline
Looks better with every update. When are you going to paint?
Chris has got a lot of talent, he's robots will be famous! I agree with Espeefan.
It got me wondering, what is the average age of scratch builders here?
Old 04-30-2012, 12:52 PM
Originally Posted by Trucker Al View Post
Chris,
Are those E-Flite 60 Amp Pro Brushless ESC's reversable? I don't think so...
Alan
That one is for the pump motor.
Reg
Old 05-02-2012, 08:00 PM
Trucker47's Avatar
Espeefan - Thank you very much!
Madda - I plant to paint once I feel that i dont need to change anything because I don't want to paint it and start thinking im done when I still have lots to do.
RCP57 - You got it!
So today i got the housing for my belt reduction system for the pump, probably the longest part i have cut to date, 1 hour 40 mins and that doesn't even include re-setting the program after somebody thought it was a good idea to hit the shop power emergency switch in the middle of a cut.
Now i just need to get the pulleys installed and it should be good to go.
Thanks for reading!
Old 05-02-2012, 09:06 PM
almost 2 hrs JK , Chris your doing a great job your fortunate to have that type of stuff in the HS . I was lucky enough to be able to have industrial shop the last year they offered it . 2 summers later they auctioned everything off No NC at that time not even a BP vertical mill .
some lathes a horizontal mill , sheet metal tools and a forge .
Old 05-22-2012, 01:34 AM
Trucker47's Avatar
ihbuilder - Thanks! Yea I really lucked out on the that one!
So Got the belt drive all finished and ready to be installed. And it came out great. It has a 2.85:1 reduction from motor to pump. I also got some other smaller parts cut out here and there. Just wanting for some metal to come in to get working on some other parts.
Old 05-22-2012, 07:05 AM
nice!!!!
Old 05-24-2012, 01:22 AM
Trucker47's Avatar
aussietrckerguy - thanks!
So today I cut out the reservoir tank out of a 2.25" x 2" x 1" block, it has a 43mL capacity, M5 Inlet and output ports and a solid top cap. Hopefully it doesn't leak but only time will tell.
Hopefully tomorrow I can get back to work on the valves again.
Thanks!
-Chris
Old 05-24-2012, 11:14 AM
Do you have a vent in it Chris?
Reg
Old 05-24-2012, 01:59 PM
Wohoo, fast progress few last days, keep it going!
I'm waiting the results, high school boy building his own hydraulics
Old 05-25-2012, 01:13 AM
Trucker47's Avatar
RCP57 - No not yet as i don't quite know the orientation of the tank so i don't want to drill a hole for the vent line and then end up having it in a spot I cant get to.
Madda - Yea I have to move quick!! Time is really sneaking up in me, my first exam is in less than a month
On that note I might have to wait for lights and such until summer after I graduate, but luckily i talked to my teachers and they are fine with me doing that.
Anyways today I finished machining the body of the valve system and now i just need to redo the face plate, make the rotars and she's good to go. Then Ill finish the cylinders and we should be good to go on the hydraulics as long as we have no catastrophes
As always here are some pictures:
Inside the tank:
Valve assembly:
Start of the lift cylinders:
Thanks for lookin!
Old 05-25-2012, 02:50 AM
So what did you do there with the valve? You going to have a pressured line & a return line coming from each valve?
What size fittings & tubings to the cylinders?
Old 05-26-2012, 04:24 PM
Trucker47's Avatar
Lil Giants - Yea on each valve i hill have a supply and return like you said with an external manifold. But looking at it now i should have milled in the supply and return lines into the valve block. Oh well, thats part of learning.
the fittings are M5 thread with 4mm OD tubing i believe, i'll try to get a pick up to showing the scale of the valves and the new front plate because that one in the pictures the fittings were to close.
Old 06-12-2012, 11:59 PM
Trucker47's Avatar
Well we sure are getting close!! I got all the electronics sorted out for now all i need is a servo slower or a servo tester to control the pump rpm/pressure. Until I accidently dropped a motor controlled and it shorted out on a metal shaving near my drill press i was even working on wood to prevent problems like this The valves are now done but I need to finish the cylinders to be able to test and see if it works. I got all the bucket linkage worked out and now need to weld and braze the bucket but i have to pick up some argon for the MIG my dad has got because our industrial sized welder at school burns through 14 GA. Heres some pics of the progress:
showing everything that needs to fit, ill cut some wires and clean it up once i know the final lengths.
Low current draw branch of the wiring harness.
Manifold from pump to valves and from valves to tank.
Finished valves:
Cab Lights
Bucket linkage
Lift and turning cylinders
Thats all for now and i've got one week to get this thing working!! Time to get er done!
Old 06-13-2012, 01:20 AM
Very good job Chris!
I wish you good luck to get everything working, you must be pretty nervous to see what's going to happen when all hooked together?
Put video here asap you get some action!
Old 06-13-2012, 02:37 AM
Trucker47's Avatar
Thanks Madda!
yea its a pretty nerve racking especially because i don't have any more time or money to fix thing if they dont go as planned. Plus so many people who have helped build it wanna see how it works so i gotta make sure it actually runs!!
Will do, might be after i get it all done but ill get some up asap!
Old 06-13-2012, 07:20 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi Chris
Looking great I'am sure it will all come toghter and work.
Very high standard of work wishing you well.
Regards
Mark
Old 07-18-2012, 01:22 PM
OK Chris, you are well outta school so where is the finished product?
Old 08-28-2012, 10:02 PM
Trucker47's Avatar
Hey sorry for the lack of updates but I needed a break, i was working 6+ hrs a day trying to finish it and needed a break before i got to tired and said screw it. Unfortunately i ran into some problems with the loader and some other things and didn't get it done in time but i got an all access pass to the shop so on my days off ill be in the shop finishing it up! Dont worry ill get it done come **** or high water!
Old 01-01-2013, 09:53 AM
D8R D8R is offline
Hi Chris, any update on the loader?
Question on your valve design, what do you use as seals between rotator and base?
Dan
