#61
that is a very nice knight hauler just redid mine also gonna post pic soon! funny i almost went with that same color shceme
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#62
your body work is great.all the corners and rounded parts or spot on. great job!!!!!!!!!!
Specializing in VW beetle water pumps! RIP FREDDYGEARDRIVE |
#63
Thanks Aaron, But you posted alot of them already, thanks. Right now I'm having major issues downloading and uploading so theres not alot I could do with them. I need some of that Hi-speed Comcast internet.
![]() ![]() ![]() ![]() Quote:
W900 when I was a youngster, my daughters favorite color on a vehicle is blue so I thought I'd give it a try again. Quote:
#64
Well I finally got it back on the table. Took it all back apart to paint the chassis and continue working on the lift axle.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More to come, Thanks for looking! |
#65
Chassis looks great!! Love that color of Blue! I bet that color really looks good out in the sun!! Cant wait to see more progress!! What did you use for your lift axle?
#66
Nice tri axle. I really like that blue. Thats a sweet lift axle! Can't wait for more updates.
One is too many and a million is not enough. Fred. |
#67
Thanks Aaron, the chassis will get another coat of blue and a coat of clear. The lift axle is a trailer axle that I cut the center out of just inboard of the inner most bearings/bushings. The center was replaced with 2 pieces of brass tube which the trailer axle sections slide into. I formed a u shaped piece of brass and soldered between the tubes. Then I formed a truss out of brass and soldered it across the top of the u and the tubes. Covered the rough edges with a little filler and primed it. I need to clean it up a bit and top coat it.
#68
Thanks Plow Jockey, the paint is Rustoleum Metalic Colbalt Blue.
#69
Well the Knight Krawler has all its own electronics now so I can put my crawler back together
. So since I'm recovering from surgery I had the day after Christmas and have got to the point of being able to walk down the stairs to my shop in the basement, I have plenty of time to build! (3 more weeks till I go back to work )I got the lift axle finished and operating, eventually I will put a digital servo in it so I can program it to get a more prototypical lift speed. Right now its a Hitec MG 645, If anybody knows how I can slow it down I'd appreciate the info, I'm using a aux switch on an AirTronics RDS8000. http://www.youtube.com/watch?v=PUpyghe-nXo I got the HPI 7:1 GRU and 55T motor mounted and the shift linkage adjusted. Still have a few thing to do before I test run the chassis. Enough typing here's a bunch of pictures. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking Kent |
#70
You have come a long way on this.
![]() ![]() The lift axle looks good the way you made it, and I agree with everyone else, that is a pretty blue.![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#71
Sweet set up, I cant wait to see this baby all together.
#72
The chassis looks fantastic.
Does the lift axle have any suspension movement to it in the down position, or is it solid? I was just thinking if it is, you may have problems with bumps takiing the weight off of the drive axles and causing you to get stuck? I know in real life the lift axles are raised in rough terrain to prevent this, I just didnt know if yours was so solidly mounted to the servo that it may cause problems on relatively small bumps. |
#73
Looking good Kent. The chassis sure looks nice with that paint on it! Is that an aluminum transmission case, or the stock one painted silver? That's a nice touch. A little bling to constrast the paint.
Nathan |
#74
Hi BRICKNICK, I'd like to see it done too but I keep coming up with little things to add to it which sets final assembly back not to mention final paint which I need at least 50 deg. to do. One of these days! Quote:
I made sure the axle suspension worked well, and that the servo was mounted in the frame and everything looked good with no interferrence to anything, set the radio up and everything worked! I was happy until I read your post and thought DUH! that won't work. So here is the simple fix. I changed servo arms and slotted it which allows fro full travel up and down.![]() Quote:
Thanks for looking and the comments everybody! |
#75
Hi Kent,
Looking good, to answer your question about lift speed, here in the UK you can buy servo slowers that fit between the receiver and servo, I have used one from here before http://www.fast-lad.co.uk/store/prod...oducts_id=9380 |
#76
Hi Michael,
Thanks for the link I think I'll have to give that a try! I tried to do some paint work and it didn't turn out. Looks like I'll have to redo the cab, probably go with a single color. |
#77
Hey Ken, this is a very sharp looking build.....i really like that lift axle setup, care to elaborate on the build technique?
![]() I have used this servo-slower and it works really good (4-7v) http://search2.hobby-lobby.com/psear...low+down+modul
#78
#80
Not a problem, pictures are always more fun than reading!
| Currently Active Users Viewing This Thread: 210 (0 members and 210 guests) | |
| Thread Tools | |
| Display Modes | |
