Old 08-05-2012, 06:05 AM
Default Re: CAT 374D L
I started to make the lower carrier rollers. First I made the brackets (32 pcs) and now I should made the rollers (16 pcs) I wish I had a cnc lathe
Old 08-05-2012, 06:17 AM
Madda Madda is offline
Are you making these rollers with mill or lathe? I know that feeling when you have to make manually same thing for numerous times. I once drilled manually over 1500 holes...
But the build is still very cool and yet fast.
What size screws are you using there?
Old 08-05-2012, 07:22 AM
Madda, those rollers will be made with lathe.
The screws are M2 steel ones. It was a quite job to make threads for all the 64 holes with three separate taps. The 2 mm tap doesn't take much to brake.
Old 08-08-2012, 01:27 PM
Finally got all of the carrier rollers done including the upper ones
Old 08-08-2012, 01:35 PM
CAT315C CAT315C is offline
CAT315C is on a distinguished road
Hemmi1966,
A beautiful project, congratulations!!
You're doing all of it aluminum?
Thank you,
Carlos
Old 08-08-2012, 01:59 PM
Originally Posted by CAT315C View Post
Hemmi1966,
Thank you,
Carlos
Pretty much yes, of course all axles and pins are steel. Also the upper frame swing bearing mechanism will be made out of steel. There will also be some brass parts in the upper frame.
Old 08-08-2012, 04:19 PM
Smile Re: CAT 374D L
This is one awesome build, Ari. It's going to be heavy and durable in the end.
Great work. Another beautiful job.
- RCT
WCMT Director -
Old 08-08-2012, 08:32 PM
Wow, looks amazing, always a plasure to watch your updates!
Old 08-09-2012, 04:46 PM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi
Most excelent work realy look forwards to your updates.
Thanks for sharing and good luck with the build
Regards
Mark
Old 08-11-2012, 01:48 PM
I started to build the undercarriage x-frame It will be possible to narrow the undercarriage for transport like in the real thing, just have to unscrew 48 bolts
I also found a nice picture of 374 beeing transported on a low loader
Old 08-11-2012, 03:49 PM
The pace you are building at is just amazing!
How many hours a day do you spend on that beast?
Old 08-11-2012, 04:33 PM
Too many
I'm on my annual leave, so I can spend more time with it
Old 08-11-2012, 07:42 PM
MitzuRazing's Avatar
MitzuRazing MitzuRazing is offline
MitzuRazing is on a distinguished road
Awesome work! And the pace is not compareable
Cnc is cool
Old 08-11-2012, 09:15 PM
plow jockey's Avatar
Wow !! Your work is amazing. Excellent work !!
Old 08-18-2012, 01:04 PM
Got the x-frame top piece and the underside corner support pieces done. I also made the boom tip reinforcement plates
Old 08-18-2012, 04:33 PM
When I look at your update pictures I start dropping F bombs... In a good way of course. There's just not that many polite ways to describe what you're doing!
Nice work Ari!!!!!!!!!!
Old 08-18-2012, 05:39 PM
carp carp is offline
looks really nice, how much does your undercarriage weigh?
Old 08-19-2012, 03:46 AM
Thanks again guys for the compliments
The undercarriage weight is now about 7 kg, that's without the tracks so it probably will be 10 kg when finished.
Old 08-19-2012, 07:00 AM
Great!
How are going to solve the problem what comes when you need to connect drive motors with the ESC? I mean that the swinging is going to twist the wires.
First tesdrive shouldn't be too far heh?
Old 08-19-2012, 07:26 AM
Great!
I'm going to use slip ring like these: http://www.hzqs.com/english/src.html
And what comes to the undercarriage test drive the only thing that's missing are the tracks
