| 1:1 Your Semi's,Trucks and Equipment Here is a spot to share your 1:1 that you drive and or operate. |
   All I know is , if this guy tried hauling wood down a winter haul road, he'd be in the ditch before he even got to the log loader! So a Canadian video eh?..... I'm thinking French Canadian !.....lol I can say that , I'm French  ....just not THAT French.....lolMario  |
 ![]() ![]()   I don't have room for that fancy stuff in my truck.Chrome won't pay my bill's in this economy ![]() Cheer's, Neil.  |
			one of them is a dummy shifter though makes it so obvious one is.
  ..all 3 sticks work..the stick with the skull on it is the low to direct splitter..center stick is the gear..left stick is the direct to overdrive select
	To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. One Bus Stop Short Of The Short Bus...  |
 Cheer's, Neil.  |
			#26
			lol...hmm I'll check into it before I believe. Alot of guys now days faking one at least. Was up at peterbilt and kenworth the other looking at a truck and I asked about it and they told me most of them are dummy ones the get requested to put in and make them move like real. lol I'll check into this guys truck before I do.
			#27
			All three work...if you watch him shift..even at night..the third stick is the low to direct..then he just uses the other two..which is you gear and the direct and overdrive select...on a standard roadranger select shifter knob you have the pull up button for low to direct and the slide button for you direct and overdrive on your 13 and 18 speeds..oh also on the 8ll
			![]()  ..my buddy did the two stick conversion on his 18spd..for his low to direct he put it on a switch in the dash just like they use to with the 15 over..deep reduction on the dash..old school=)
			#28
 Yup! Cheers, Neil.  |
			#30
			that dudes nuts ill stick with my one lever 13s and 15 spd,on my routes them 3 levers wouldnt work to many curves,he must enjoy shifting
			#31
			A real 2 or 3 stick truck does not use air to split,shift,range select....just saying...
	Give me an old quad box and I will show you what twin sticking is about...  |
			#32
			I used to slip seat a Ford & Diamond T dump trucks, 1 had 5 & 4, other one had a 4 & 4.
	The fun part was, both stick's were opposite between the truck's. Cheer's Neil.  |
			#33
			maybe for strictly truck shows but for every day chores f!@# that i get annoyed with my 10 speed on 94 sittin in traffic
	Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.  |
			#34
 Traffic jams suck! Cheers Neil.  |
			#35
			I found another video today, the hamster steers the truck! LOL! It's on Big Lorry Blog, http://www.youtube.com/watch?v=7N87uxyDQT0
			Just when you thought , you had seen it all ![]() ![]() ![]() ![]() Cheer's, Neil. Last edited by doodlebug; 09-12-2013 at 09:41 PM.  |
			#36
 there will always be something to see. The levels of stupidity and crazy stunts to be thought of will entertain us for a lifetime! ![]() ![]() Mario  |
			#37
			Just found this one, a 450 ton Russian Haul truck. Reminds me of a 350 Payhauler.
	http://www.mining.com/belaz-launches...ampaign=digest Here's the spec sheet, http://www.belaztrucks.com/wp-conten...10_ENGLISH.pdf And it's in the Guinness Book of Record's Cheer's, Neil.  |
			#38
			stupidest thing I have ever seen . I do not drive professionally any more but I do have my frieghtliner rv hauler and I think this is just plan dangerous.
			#39
			I drove a Mack DMM from Florida to Minnesota. Holy crap   that was a cluster...finely got good at it once I got to Iowa boarder
	Specializing in VW beetle water pumps! RIP FREDDYGEARDRIVE  |
			#40
 I once drove a setup similar. There was a 4 speed brownie box, with a 5 speed main box, & behind that was mounted a modern 13 speed transmission. Other then show, there's never a need to move the 5 speed mainbox, but there is occasionally a usefulness to shift the brownie box.  |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| Thread Tools | |
| Display Modes | |
