Old 11-26-2012, 12:32 AM
powerstroke_1999 powerstroke_1999 is offline
powerstroke_1999 is on a distinguished road
Default Mercedes 1850 converted to 4x4
Hey guys I was wondering what you all thought would be the best way to convert one of these 1850L delivery trucks to a 4x4.I just ordered one Friday I was thinking of using the tamiya high lift front axle.And a transfercase from rc4wd To connect front and rear axles to transmission.I want to run rc4wd 1.9 mud plugger tires and humvee beadlock wheels.Not sure what I will have to do to the rear for the wheels because its a dually unless I change out the rear axle to.
Old 11-26-2012, 08:08 PM
Tamiya Cowboy's Avatar
Default Re: Mercedes 1850 converted to 4x4
Run a tlt in the front and in the rear you wont be able to run a dual set up with the beadlocks they will stick out to far even on a semi axle that is how other guys have done it Russ did one a few years ago maybe he can post some picks.
Paul W. "Tamiya Cowboy"
Old 11-26-2012, 08:31 PM
russisloud's Avatar
heres a few to look at
Old 11-26-2012, 09:58 PM
Russ your fricken AwESOMe! Them are sweet!!
Old 11-26-2012, 10:14 PM
Man those trucks are sick !!!!!!!!!!!!!!! bad a$$ man what axles did you use in yours.Did you use the trans out of the f350 high lift and the leaf springs.
Old 11-26-2012, 11:59 PM
russisloud's Avatar
the two 4x4s are mostly high lift running gear
Old 11-27-2012, 12:46 AM
Where you able to keep the stock steering setup for the 4x4s
Old 11-27-2012, 11:43 AM
Stuart's Avatar
Stuart Stuart is offline
Check out this thread of my Merc 4x4:
http://www.rctruckandconstruction.co...ead.php?t=4321
Old 11-27-2012, 06:53 PM
russisloud's Avatar
building a 4x4 really isn't too hard to do. those merc's where built a few years ago, but i think i just used the stock servo mounting and made up some new tie rods.
Old 11-27-2012, 07:27 PM
Ok man i ordered a tlt front axle and the high lift f350 leaf springs.For the back axle I'm gonna buy the 12mm x 12mm spacer for the back axle so I can run the bead locks I want and the 1.9 mud plugger tires.
Old 11-27-2012, 07:33 PM
OK. Now you guys are making ME want one! Dan
Old 12-04-2012, 05:39 AM
evo mike's Avatar
evo mike evo mike is offline
evo mike is on a distinguished road
Hi,
Just wanted to throw in this pic.
It's an older Wedico Mercedes truck 1936 I transfered to a 8x8.
Using TLT axles and a RC4WD gearbox V2 with 2 motors.
Mike
Old 12-11-2012, 07:59 AM
Well here are some updated pictures of the build not done yet.
Old 12-11-2012, 08:01 AM
Old 12-11-2012, 08:04 AM
Just some mock up of the driveshaft had to order some shims from rc4wd to correct the pinion angle will take some pics of it when they get here.Also ordered my new wheels and tires 1.9 mud plugger and humvee bead locks.
Old 12-11-2012, 08:07 AM
Also changed the rear leaf spring mounts and moved the shift servo back more I will upload more pics later today.Got my 4x4 trans from tamiyacowboy thanks again for everyones help and iput on this build.
Old 12-11-2012, 08:11 PM
low&slow low&slow is offline
low&slow is on a distinguished road
Gotta love the 1850! Nice build so far.
Old 12-12-2012, 08:30 AM
Thanks man just got my wheels and tires today and my axle shims will be here friday!!!
Old 12-12-2012, 08:56 AM
Christo's Avatar
Christo Christo is offline
Christo is on a distinguished road
Why didn't I think of 4WD, What is the difference between the original and new width of axles?
Looking forward to seeing more updates
Old 12-12-2012, 01:47 PM
the front axle isnt much wider like a hair wider and I reused the rear axle
