#201
Ari, nice looking cylinders. Du you solder the ends or are they glued to the tubing?
What pressure will you use in the system? Dan |
#202
![]() Cylinders will be silver brazed, here's one that's been brazed:
#203
wow you just keep out doing your self. what will hold the stick cylinder on a snap ring on the out side? are the bolts for the hose adapters end real or just on there and brazed on? thanks for showing us your work.
#204
So what's the bore of the cyls and what size (ID) plumbing do you intend to use?
#205
Those M1.2 bolts are just for decoration, those hose adapters are brazed.
#206
Cylinder bore is 18 mm and hose ID is 3 mm.
#207
Made some plumbing today
#208
Very neat!
What do you use for brazing? |
#209
#210
That brass and soldering work is phenominal!!! I sure wish I could solder that clean in that small of a fitting with brass. Can't wait to see this machine operating.
Keep it up. Tyler
~Tyler~
RockSolidCustoms |
#211
Ari every time I look at this thread my Jaw drops ..You are really setting the Bar really high now ..Hats off so far a perfect peice of art
#212
Got the boom boxed, and cylinders finished. Now I should get my hydraulic pump up and running to see if there's any leaks on the cylinder tubing.
#213
Stunning!! Cant say more then that it looks fantastic, great job on the cylinders, hope they are leak free!
#214
Beautiful job Ari! I'm sure that with your skills there will be no leaks
#215
I machined the tracks narrower, they are now 72 mm wide which is around 1 meter wide in full scale.
For my eyes they look more realistic now. Here's a picture of the left track still wide.
#216
Spot on! That looks so much better!
#217
Here's both tracks done
#218
looks great hemi loving the detail ur putting into it
#219
Ari, looks better with the narrower tracks, the bigger machine, the narrower tracks it looks like.
This pic from a Swedish forum ![]() What size is the L-connector on right side, M5? ![]() Like your small connections (brazed) to cylinders, wish I had thought a little more about how to make those earlier. What´s the size of cylinders (good to know if I will build another hydaulic model, easier to find brass tubings). Dan |
#220
nice work
i would like to have more information on how did you do the track pad Steve |
| Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
| Thread Tools | |
| Display Modes | |
