Old 12-15-2012, 12:38 PM
Default Sliding the axle forward on a Tamiya
Hi guys, I'm looking for some advice. I've seen some of you slide the steering axle forward on your King Haulers and K100 converted Globe Liners. Question is how are you guys doing this? What's all involved, and how hard is it to do?
Old 12-15-2012, 01:09 PM
Default Re: Sliding the axle forward on a Tamiya
It is easy just loosen the U bolts slide the axle forward to the desired position and tighten the U bolts down.
Travis
Old 12-15-2012, 03:00 PM
Claus's Avatar
Claus Claus is offline
Weren't some of you guys tilting the front spring shackle or something as well? Didn't that lower the front end a little bit?
Old 12-15-2012, 03:33 PM
Thanks Travis. I thought for some reason the Tamiya axle had locating dimple in it, that matched the rivet in the spring pack, or am I wrong? You guys are just relying on the u-bolts to clamp it down then, and not the rivet? Not that it's a big deal. I thought I also heard of guys using a shim from the High Lift kit to level the axle back down. To much caster otherwise? Think they offically call the shim a pinion kick up plate, or caster plate.
Old 12-15-2012, 06:08 PM
Brian in PA's Avatar
I'd rather be truckin'
On all of my Pete builds I re wound the front eye of the spring with a pair of needle nose pliers. I got this tip from Jammer and it works very well. I also rotate the front shackle up in the front. This allows for a slight drop in ride height too.
Brian
Old 12-16-2012, 06:35 PM
Chris and Brian, thanks for the added input! I appreciate it. Thinking about building a Tamiya, just for kicks. Thought I'd do a little research.
Old 12-17-2012, 02:25 AM
easytruckin's Avatar
easytruckin easytruckin is offline
easytruckin is on a distinguished road
Hello,
Hope it can help you, here is what I've done:
http://easycure.fr/easytruckinltd/?p=335
see ya'
easycure
Old 12-17-2012, 09:44 PM
Thanks easytruckin'. That's helpful to me. I appreciate you sharing the photos and info. I'll be ready to give this shot, when the time comes.
Old 12-21-2012, 12:02 AM
Tim, that looks a really nice solution, and it's nice that the axle stays level. I think I could handle making a new front suspension hanger, just like that. Thanks for sharing your idea. I am sure I've seen it mentioned in your very detailed build thread, but I may have forgotten about it! As you Aussies might say, looks like it works a treat!
Old 12-24-2012, 05:28 PM
Thanks Tim. I appreciate the information, and you taking the time to share your techniques with me. I know you have a lot more experience then I do with building these Tamiyas into some really nice, realistic trucks. I still have a lot to learn.
Old 02-23-2013, 05:26 PM
Snochaser's Avatar
Good tips gentleman. Thanks
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
