Old 10-20-2012, 07:32 PM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
Talking realistic beacon
Hi there,
I finally managed to build a funtional prototype of a real rotator beacon for my Kenny. ..I will have to build a second one.. but first, I need to test this first prototype.. and I need to find a way to connect the motor properly.
I used 1.8mm Leds and coals from a 130-type motor to transfer the current.
Here are the pictures and movies:
..and the movies:
I hope you like it.. now I'll run some tests on the beacon to make sure it runs for more than just a few seconds.
Cheers
Pip
Old 10-20-2012, 11:13 PM
Goose19's Avatar
Goose19 Goose19 is offline
Goose19 is on a distinguished road
Default Re: realistic beacon
that is very impressive! looks like the real deal! i dont suppose you have some more build pics?
very nice work!
Old 10-20-2012, 11:32 PM
Wow, that's some delicate handywork!
Cheer's, Neil.
Old 10-21-2012, 04:13 PM
Exclamation Re: realistic beacon
Hi there!
thanks for the comments!
I started on beacon #2 today and made some pictures:
Required parts:
1.8mm Leds, soldered in parallel:
130 motor brushes (removed the "bumps" marked in red to save more space)
beacon assembled (not really.. actually I didn't even properly solder the can):
Positive is transmitted thru the center and negative thru the copper ring in the base (via brushes and magnet wire inside the inner tube). The positive brush will be sitting inside the cab as is the motor and the negative inside the base. Everything can be disassembled (but I hope I'll never have to).
Here's another vid of the proto. It ran for three hrs today, working perfectly:
Cheers
Pip
Old 01-11-2013, 01:53 PM
Hi there,
I didn't have much time for hobbies lately but I managed to finish the two beacons. Now I have to find the courage to bolt them on the Kenny.
Here's the vid:
Cheers
Pip
Old 01-11-2013, 06:48 PM
dabears's Avatar
dabears dabears is offline
Those are super cool looking!! I like them!! If it wasnt for needing the mortor under them they would be perfect on my lowboy! Great job on them
Old 01-11-2013, 07:06 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Nice work Pip, they look the part!
Old 01-11-2013, 10:13 PM
Nice work Pip! Much cheaper then the other SM LED simulated rotating beacons that available, I am sure. And these are nice because you made them yourself. Give yourself a pat on the back!
Old 01-21-2013, 12:21 AM
D8R D8R is offline
Working just like the real ones, uneven speed, very nice.
Will remember this for upcoming models!
Dan
Old 01-21-2013, 07:12 AM
Thumbs up Re: realistic beacon
Thanks a lot for the positive replies!
I still haven't found the courage to bolt the lights to the Kenny. I'm so scared I might screw up my nice cab..
Cheers
Pip
Old 01-24-2013, 03:37 AM
buzzy16 buzzy16 is offline
Vey cool little homemade job, and a nice thought out compact design. Good work.
