#81
pictures big or small are better then no pictures!!
#82
Stuff: The pictures were resized too big by accident. |
#83
I got some more done with the boom hoist and some on the base of the boom where it attaches to the revolving frame.
Motor pinion ![]() Boom hoist worm gear and a graphic of it on the monitor on my mill. ![]() ![]() ![]() Cutting mounting plates ![]() ![]()
#84
Very nice steve! I don't understand the monitor thing or the brass plates, but I like the work it's doing! Be interesting to see the finished parts.
#85
![]() Steve , how long did it take to mill the worm gear ? will you have the boom ready for january ? I'm on the push to get the pan running for cabin fever IHSteve
#86
Tom, the graphics are a tool path simulation before actually turning on the spindle so I can check to see if there's any weird moves I've screwed up on while programming.
Steve, I bought the gear. I just wanted to dress it up to look like the 1:1 version. But that took 2hrs to do.Look at the picture in a previous post. I'm just trying to get moving on the boom. Soo much more design to do then get real good at silver soldering ![]() I think I have all the metal needed now but I'll have to get about 200' of cable to reeve it up but before that's done I have to remove the "A" frame and machine the holes for the sheaves up there. It would be a miracle if the boom is finished. |
#87
Steve , in that 2 hrs , how much tool time and how much program time ? If the fund don't come in time then I'll be making everything for the hydros cept hose , fittings and seals . hydros put me back last year but not now with a mill in the shop even if it's a toy it still makes life easier . I looked at some of those booms on stripmine
I can see that taking some time and a few more grays on the chin ![]() IHSteve
#88
The program only took about 5min but getting in the old mill didn't work. I was trying to rotate the pie shape on the mill but it didn't work. Long story. After a couple trips back and forth to the computer I figured it out. Now that I think of it maybe 3hrs in all
I took small cuts because I didn't have a good hold on the gear and if it got ######up I would be out some $$$ If it was held better I could hog that out in an hour. The 6 plates took about 50min.
#89
I was just trying to figure times , I'm trying to get a hold of a cnc bp missed out on one that had the phase converter with it . went for $2555.00 nice shape to
I'll just keep trying . it's hart braking seeing nice machines for a good $ and not having the $ when you need it IHSteve
#90
That is some beautiful work Steve, I can only dream of doing that kind of stuff.
Joe |
#91
Wow, that wheel looks so much better when milled, guess you have to run the machine without any superstructure on it. when milling in brass, how much do take in each pass?
Guess that with the time spent in machine, it would be max 1/16. Will it be milled all way? I have a RF35 milling machine, do you know of any good and cheap conversions for CNC. Guess that most CAD program can export right format to the CNC. When I draw for laser cutting most companies want DXF files. my hat of, Steve, looking forward for progress. Dan |
#92
Steve, what I ment was it´s a shame to cover all this beautiful machinery covered up with sheet metal. You have put so much work into it so it has to be seen. Maybee a removable roof?
Here´s a pic from HCEA2008 It must have taken lot of hour milling out those sides ![]() is it same type of control on the drums as this old model but with r/c servos?
#94
Oh, I'm going to cover only half of the machine-The cab side. Yes I'll leave some of the roof open and the left side and I'll have lighting inside. I still need to make the big supports for the walking bearings that go into the roof and I have to make the curved roof trusses. The 3 motors are controlled with 100VDC regenerative drives similar to the 1:1 but solid state. The rc part was a real learning experience. When I have all that 100% I'll show more detail on that. I'm still on the trial and error method
I'll have to post some of my progress from this past weekend on the boom.I would love to have that stiff leg derrick toy that guy had at the show. I forgot to take some pictures of it like you did. |
#95
Here's some progress on the boom.
Fixture for side of first section. ![]() This is the first piece of tube cut and notched of hundreds ![]() ![]() ![]() Checking for fit.
#96
Looking good Steve!
Great idea on the fixture to make it.
#97
Steve-I cannot even imagine how long that is going to take but you will be rewarded. It should look "outta this world"!!
#98
Steve-you may already have a plan for your silver soldering but I thought I would mention this. I had a lot of problems soldering joints close to each other. The heat would melt the joints loose. If you are soldering both inside & outside of the boom this may be a problem. I found this stuff after I had finished my project but it looks like it will do this job. It is called "cool blue" heat paste and it seems pretty amazing. They have some videos of it being used and you might want to check it out. It is pricey but you can re-use it many times. Here is a link-
http://www.muggyweld.com/hpclip1.html |
#99
great work! very inspiring!
thanks for sharing, Kerst |
#100
Thanks Kerst..
Tom, I've heard of heat blocking putty. I think we tried that 25yrs ago but we never needed it for our work but like you said; It may come in handy for the intricate work on the boom. I have a tiny jewelers torch if my resistance soldering setup doesn't work. I hope with the resistance machine it will locate the heat right where I need it. Something I noticed with the closeup picture that's hard to see without glasses is the tube bends up on the ends. My slitting saw needs to be a couple thousandths wider. My milling was on the big side of my intended size because trying to mill those long pieces,it's hard to hold straight and no deflection. I would love to have a vice setup with 32'' long jaws but I never built one. Last edited by 9W Monighan; 10-05-2010 at 01:31 PM. |
| Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
| Thread Tools | |
| Display Modes | |
