Old 02-07-2013, 10:36 AM
Default 1:16 Pulling sled
Hi together!
For some time we habe been spending time in buliding a 1:16 scale pulling sled. Here is the result:
Drive sprockets from the axles...
...to the wheight box chain.
Should be finished for our farm model show in June...
regards,
Frank
Old 02-07-2013, 10:44 AM
Default Re: 1:26 Pulling sled
The gears on the right side are needed to adjust the full-pull distance at about 5 meters...
They let the weight box chain turn slower as the axles...
regards,
Frank
Old 02-17-2013, 10:53 AM
Default Re: 1:16 Pulling sled
Some small steps ahead:
the gound palte for the weight box is fixed...I guess in this "unloaded" condition I will already have to fill the tires...
regards,
Frank
Old 02-17-2013, 12:15 PM
Grainy:
Why not seal the tires to the rims (CA usually is the method) and then see if you can get a very fine needle and reasonable capacity syringe, and 'inflate' the tires to a set pressure.
I've been saving my TPN bags, syringes, and a few sets of tubing (well-flushed) and the boat guys were happy to accept various bits, as they make gread variable-weight 'ballast bags' for boats, and even water reservoirs for water cannons and such.
I'd offer a few 27 guage needles, and some 10ml syringes, (new in sterile packages) but I'd bet that Customs would pinch 'em. Ask at the pharmacy, these days they are pretty good with small quantities... (if ya can get smaller than 27 guage, even better, think 32 is about the smallest)
Alternately, you'll wanna use foam-fill... easily sourced at your average R/C shop.
WhiteWolf
Old 02-17-2013, 07:03 PM
Claus's Avatar
Claus Claus is offline
Awesome build Frank!!!!!!
Old 02-17-2013, 07:13 PM
Nice work, Frank! I've always wanted to see one of these built. It will be even more fun to watch the tractors lug it down the track. Make sure you get some video footage!
Old 02-18-2013, 06:34 AM
@ White Wolf!: Thats a good idea. Maybe I´ll do it this way.
We will need the sled at our agricultural model expo in june this year. Then we will get a video...
http://www.rctruckandconstruction.co...ead.php?t=5449
We already have about 70 registrations with about 120 models...
regards,
Frank
Old 02-18-2013, 08:38 AM
Acadieman Acadieman is offline
Acadieman is on a distinguished road
The tractor that I'm most interested in seeing pull is the MF1155.
Old 02-26-2013, 08:16 AM
Some more details of the transmission...:
All torque transmitting sprockets and gears are fixed with zylindrical pins on the shafts. With te complete weight in the box I do not trust a small setcrew...
regards,
Frank
Old 02-28-2013, 12:55 PM
Some more steps ahead...:
In the following pictures you can see the levers and mechanic system to lift up the rear end of the skid plate at the starting line. After about 3 ft distance the weight box lets the levers move up and the complete sled plate touches the ground.
The original sleds do it the same way. Lifting the rear end of the sled palte up makes it easier to accelerate the "vehicle" at the starting line. At this moment there is almost rolling friction, later when the plate is pushed down it becomes sliding friction.
In the middle of the weight box you see a thick brass bush. It contains the locking pin for the chain...The pin drops into the free space of the chain link.
regards,
Frank
Old 04-28-2013, 05:49 PM
Hi together!
Here´s a first test video...:
http://www.myvideo.de/watch/9091379/Bremswagentest1
Regards
Frank
regards,
Frank
Old 04-28-2013, 05:52 PM
Claus's Avatar
Really enjoyed that Frank, great build, you make me wish I had a tractor!!
Old 04-28-2013, 05:57 PM
...keep going...you have enough red ones...
regards,
Frank
Old 04-28-2013, 06:32 PM
Great video, Frank! Do you have anymore?
That John Deere pulled the sled a lot further then I thought it would. What kind of model or conversion is it?
I'm with Craig.....I want a tractor!
Old 04-28-2013, 07:33 PM
SmallHaul's Avatar
Nice work on the pulling sled.
Scott
"No load is too Small"
Old 05-31-2013, 10:57 AM
Very nice. So after the fields are plowed and planted, the farmers can play!
Old 05-31-2013, 12:59 PM
louie r/c nut louie r/c nut is offline
louie r/c nut is on a distinguished road
Nice sled like the video
Old 01-03-2014, 09:53 AM
ptebbe ptebbe is offline
ptebbe is on a distinguished road
Nice project. How did you come up with the chain drive??
Paul
Old 01-04-2014, 11:17 AM
Hi Paul!
The chain drive is the easiest way for the transmission in this case I think. Just some sprockets and shafts, no bevel gears...
At the moment I will have to do some repairs: Tightening the sprockets on the drive shafts of the axles. They are fixed with a set screw, but that is not stron enough I think. We´ll do it with a cylindrical pin...
regards
Frank
regards,
Frank
Old 04-28-2015, 01:09 PM
Hi together!
...some progress...nearly ready for the paintshop:
regards
Frank
regards,
Frank
