Old 02-19-2013, 07:56 AM
Default Re: CAT 374D L
That's a bit extreme, what do you have the pressure set to?
I'm at 22 bars now.
Old 02-20-2013, 12:10 AM
Nice work as always Ari.
I guess it's so powerful due to the size of the rams? Am I correct in thinking that the bigger the ID of the cyclinders the more powerful they are?
What's your thoughts on the Kampfer ventil/valves?
Elliot.
Old 02-20-2013, 09:02 AM
Yes you are right Elliot, larger diameter cylinders are more powerful.
On the down side they also need more capasity from the pump and also larger hydraulic lines.
My cylinders have 18 mm bore, so they are not that large.
I'm very pleased with the Kampfer valves so far
Old 02-21-2013, 05:58 PM
izzzul izzzul is offline
izzzul is on a distinguished road
superb work here...! really amazing to look at..again and again..
Old 03-03-2013, 06:06 AM
I've been working with the counterweight and it's turn out to be nightmare to make I wish I were able to make it like Steve (ihbuilder) in one piece, but my cam program won't do 3D (I think)
I also did some welding on the counterweight with Durafix but it really does not work well when you have to brace different thicknesses together. The thinner plate tends to expand more while heating and it goes curved, and when everything cools down and shrinks, it doesn't look too good
I'm seriously thinking about buying small TIG welder, it looks like you can make very small welds with it without heating the parts too much. Been watching Reg's Kenworth 850 build and hope I can some day learn to weld that well
Old 03-03-2013, 06:50 AM
JAMMER JAMMER is offline
Ari you have nothing to be ashamed of when it comes to your work you have a talent. Ed
Old 03-03-2013, 06:56 AM
Thanks for the ego boost! I think a TIG would serve you very well Ari. It can be a little challenging at times especially when welding two different thicknesses of material(at least for me). It would be nice for you to be able to weld together some things instead of drilling and threading for fasteners. CNC cut panels would weld together sooooo nice! Keep up the great work! This machine is awesome!
Reg
Old 03-03-2013, 07:04 AM
dabears's Avatar
dabears dabears is offline
Ari anything can be fixed with filler and paint. your build is killer looking!!!!
Old 03-03-2013, 08:17 AM
Madda Madda is offline
Ari, great job there!
Maybe you should get better CAM? Also for that one part, why not try a demo of some powerful program? You could get the part done even if you don't buy the 10k per year CAM system Just some thoughts
That shiny aluminium looks so good, maybe you don't paint it?
Old 03-03-2013, 10:21 AM
Ari , what cam are you using ? I had a few issues at 1st but the more I use it the better I get .
Old 03-03-2013, 06:26 PM
cdm cdm is offline
or in that case aluminum flux, then power sand down on the belt. has like 30000psi strenght vs 2000 (at best) for filler.
given all i've seen im surprised thats all the items that didnt come out right. you are way better than me thats for sure
Old 03-09-2013, 10:18 PM
I'm using this: http://www.industryarea.com/Metal-wo...catalogue.html
It's very simple to use but it has it's limitations
I did some plumbing work
Old 03-12-2013, 05:29 AM
Roadbuilder66 Roadbuilder66 is offline
Roadbuilder66 is on a distinguished road
Looks great!
Old 03-24-2013, 06:58 AM
I made the first parts for the cab
Old 03-31-2013, 03:14 AM
I got the tubing on the boom done and also few parts for the cab
Old 03-31-2013, 06:26 AM
kerst's Avatar
kerst kerst is offline
Beautiful!
Kerst
Old 03-31-2013, 08:14 AM
Absolutely beautiful!
Old 03-31-2013, 08:17 AM
Looks great Ari! Looks like a bead of weld needs to replace that tape on the cab....
Old 03-31-2013, 09:07 AM
Snochaser's Avatar
Need to be mass produced!!!! I want of these too!!!
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 04-06-2013, 03:54 AM
More tubing
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
