#121
Wow that is quite the paint job, stacks and all!
#123
there is a guy on RCC that goes by the screen name MTHead, that can make the cummings logo you're after, and it'll be chrome. he's very reasonable as well. here's a pic of a custom grill emblem he made for me for my yota crawler.
![]() it actually has sorta brushed aluminum look, and has a satin black outline, and they are self adhesive. he can make you anything you want, any size scale. |
#124
man that truck is just to perfect!! great craftsmanship and details. those tanks are so cool and all the hardware on the frame is eye candy great looking truck
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#125
Not sure if anyone has mentioned this, but congratulations on Build of the Month for March, Nathan! This is one impressive rig, and it deserves every award and complement given to it, and it's builder! Great work, buddy!
Now, let's see an update!
-Chris To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#126
Hey!,hey!, hey! What are those tasty German treats in the background? Are you putting some Hillbilly in this truck?
#127
Simply beautiful Nate. Great work and attention to detail.
Ben
#128
Congratulations on your contest win! Well Deserved!
Jason |
#129
Thanks Craig!
Thank you egronvold! Quote:
Thanks Kent. Sent one back to you too. Quote:
Not sure what she weighs yet, farmhauler. It gets a little heavier with every update though! That's pretty darn fancy! I like some things about the paint scheme, but not everything! Stacks should be chrome, or stainless. Still thinking about color ideas, but I haven't decided yet.Quote:
Why it appears as though someone stole the rear ends off the Hillbilly Deluxe! Quote:
Thanks JD. And thanks to everyone who took the time to check out my build, and decided to throw a vote in my direction. I appreciate it guys.
Nathan |
#130
And now for an update!
Love'em or hate'em, I finally made up a set of big fat stacks for the 1950 KW, and because I needed the cab to be removable for battery access, I also ended up maching a set of stack mounts, so the stacks could be left on the chassis. ![]() ![]() Don't worry, the zip ties are just temporary. When I get the stacks drilled for mounting holes, scews will hold everything together. The stack height is yet to be determined, although it's pretty darn close to where the stacks will sit. I am also planning on making some cross bracing to tie the stack mounts together, and they will probably bolt to the chassis deck plate, which is yet to come.![]() ![]() ![]() I'll have to send the stacks out for chroming, eventually. I found a somewhat local chromer, in my state that I'm going try out. As soon as I get a few finishing touches done on the mounts, and stacks, off they'll go! I'm kind of looking forward to that. I hope they turn out nice.
Nathan |
#131
Looking good Nathan! Are we not having a rear window? Underneath the stack of tires hanging on the wall is that a hot rod engine?
Jimmy |
#132
Forget the hot rod engine, How about the Optimus Prime Prison Guard? Why Aint this truck finished yet boy!?
Jason |
#133
Looks Killer Nate!
Jason |
#134
I think the window will be one of the easier things to finish. That is a hot rod engine, in the background, and a partially completed pinewood derby car for the engine to go into. There is an annual adult pinewood derby car contest that is put on by a local group every year. I thought I'd give it a shot, just for fun. Quote:
Nathan |
#135
Nathan, awesome! You're killing me, making me want to ditch my sleeper and chop a couple inches off my frame.
#136
Nice job! Those stacks are huge! I didn't like them at first but the more I look at the pics and imagine them chromed the more they grow on me! Keep up the good work!
#137
Nathan,
Just had a thought, the rear window oval shaped? Kinda old schoolish. Might fit with the retro mod look. Jimmy |
#138
Jimmy, good idea, although I feel an oval window look better on a Peterbilt. Just because the Peterbilt emblems are oval too. I really don't have an easy way to mill out an oval either. I'd have to ask one my machinist friends at work to do it with one of the CNC mills. We'll see!
Nathan |
#139
Time for a weekend update guys.
![]() The Kenworth turned into a glider, but for good reason! I got some new goodies to add to the build. ![]() ![]() ![]() Santa 'Claus' dropped off an early Christmas present. Thanks Craig. You are a heck of a friend. A little bit of the Hillbilly Deluxe will live on with the Kenworth now. I spent a little time this afternoon cleaning up the casting lines on the new axles, and swapping the hardware for stainless screws and nuts. They'll look great when, and if, I paint them now. ![]() ![]() It might be hard to see, but I am re-working the torque and radius rod mounts, so I can get improved 4 link geometery. I machined up a couple blocks that bolt to the bolsters, replacing the original L-brackets that were used before. I'm also going to work on new top link mounts for the axles. More pictures to come, as I make some progress.
Nathan Last edited by Espeefan; 04-14-2013 at 05:39 PM. |
#140
This build is really amazing Nathan. I love all the detail and hard work your putting into it. Can't wait to see more!
Look'n neat with no air in the seat |
| Currently Active Users Viewing This Thread: 141 (0 members and 141 guests) | |
| Thread Tools | |
| Display Modes | |
