Old 05-27-2013, 06:51 AM
titandigs's Avatar
titandigs titandigs is offline
Aussie Fabricator
titandigs is on a distinguished road
Question Spektrum DX10 system fault
Hy Guys, I purchased said item at Dortmund this year for one of my new models, The model that it is going into is ready for the transmitter testing.
After connecting all of the servos all was good, turn off the transmitter came back to it later turn it all on again and this came up.
Has anyone had any experience with this issue?
Old 05-27-2013, 07:56 AM
thercfreak2012 thercfreak2012 is offline
thercfreak2012 is on a distinguished road
Smile Re: Spektrum DX10 system fault
did u buy it new or used because that may be the problem
Old 05-27-2013, 08:29 AM
titandigs's Avatar
Aussie Fabricator
Default Re: Spektrum DX10 system fault
Yes it was new out of the box from TTM in Germany
Old 05-27-2013, 03:24 PM
Hi Paul,
Hold the black roller button down for 5 to 30 seconds and it will clear..
Elliot.
Old 05-27-2013, 03:27 PM
did paul sort it out mate
Old 05-27-2013, 07:25 PM
have u fixed the problem
Old 05-28-2013, 06:51 AM
titandigs's Avatar
Aussie Fabricator
Thanks Elliot, I did what you said and it now works fine. How did you know about the fix?
Paul
Old 05-28-2013, 08:42 AM
elliot is talented
Old 05-28-2013, 02:09 PM
Paul
Hi Paul, glad it worked. My radio did the same a few times, its a problem with Version 1 of the software. Sometimes it clears by itself but once I couldn't get rid of it, so I called horizon hobby and they told me about holding the roller button done until it clears.
Elliot.
Old 05-28-2013, 06:20 PM
apfubar apfubar is offline
I would suggest upgrading the firmware on the 10t if you haven't already.
Note: you should backup you models to the SD card before doing so. You may also need to re-bind the models.
Cheers,
AP
Old 06-06-2013, 08:05 AM
titandigs's Avatar
Aussie Fabricator
Red face Re: Spektrum DX10 system fault
Cheers,
AP
I have upgraded the firmware and it has solved the problem,
Now it takes about ten seconds for the transmitter to boot up.
Prior to the firmware upgrade it would boot up in about 1 second.
It's not a big problem but its not the same as it was out of the box any ideas?
Thanks Paul
Old 06-08-2013, 04:13 PM
Paul,
Mine takes a while to start up as well, not 10 seconds though.
I might try and ask Spektrum to comment on the boot time (it does feel long).
I will also check my DX8 and see if it is the same.
Cheers,
AP
Old 06-10-2013, 01:49 AM
titandigs's Avatar
Aussie Fabricator
Ok thanks a lot
Paul
Old 06-15-2013, 06:34 PM
Paul,
I did ask Spektrum about the boot time, apparently it is due to the additional complexity. The dx18 is similar to the 10t.
FWIW I have been playing with the spam files, from bog the 8 and the 10t, the 10t's ones have a lot more stuff.
Cheers,
AP
Old 06-16-2013, 12:31 AM
titandigs's Avatar
Aussie Fabricator
Paul,
Cheers,
AP
Thanks for the reply, its good to know its not a fault.
Paul
Old 06-18-2013, 12:03 PM
I have a comment from someone in the know in Spektrum whom reckons 8 mixes are available on the DX10T.
Today I tried some stuff with the mixes on the radio, and documented how i did it:
https://docs.google.com/file/d/0B6LW...it?usp=sharing
I do know that whilst I can't see the mixes once I move them they do still work. Just not sure how many active ones I can have.
Cheers,
AP
Old 06-18-2013, 08:36 PM
titandigs's Avatar
Aussie Fabricator
Can't open the link, can any one else open it?
Old 06-18-2013, 08:38 PM
justin justin is offline
justin is on a distinguished road
Yes I can
Old 06-20-2013, 05:19 AM
All,
As an alternative you can try downloading it from here:
https://sites.google.com/site/txprof...edirects=0&d=1
Paul,
I have just sent you a PM as well.
Cheers,
Andrew P
